October 24, 2026, 05:15:41 PM
391 Guests, 0 Users
  • Online today: 522
Guests: 391
Total: 391
ISLOGO
What is Instructor Station™ ?
The Instructor Station™ is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station™ allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
iStation does not connect to FSUIPC (remote access)
Started by luisgordo, November 17, 2010, 05:18:55 PM
luisgordo
Symptom:  Instructor Station does not connect to the FS Server (from remote computer)
Probable cause:  Multiple.
Solution:
Check the following:
1. Disconnect the "dynamic WXR" setting in FS.
2. Check if your firewall is blocking the way out.
3. Please also check your wideclient and wideserver are properly running.
4. Try disconnecting and reconnecting to FSUIPC from the Instructor Station program menus.
5. Check you have Microsoft .NET Framework 3.5 installed.
6. Try to run the program on your FS server computer, to discard any other problems.
7. Check you have the latest version of the Instructor Station. Check at:
http://luisgordo.googlepages.com/instructorstation
Instructor Station
www.iStationGordo.com
Flight Data Recorder Mobile
