October 23, 2026, 06:28:04 AM
263 Guests, 1 User
  • Online today: 524
Guests: 263
Total: 264
Large Golfballs Under Cockpits
Started by NeoMorph, January 27, 2011, 03:23:33 AM
NeoMorph
I was taking climbing out from this airport yesterday when I spotted an Airbus coming into land. This was the day btw so I wouldn't have expected the plane to have landing lights on but instead of lights there is this wierd large golfball thing there the landing lights on the forward undercarriage is.
Is this a glitch because since then I have spotted other planes with the same effect and wondered if there was a way to fix it because the planes look silly like that.
Hi Neo
Most (at least all the ones Ive seen) aircraft operating manuals/checklists call for using Landing Lights for both take off and Landing at any time of the day. (Checking LJ45 manual now....Yes, this is true for the LJ45 at least). I believe the same for the 737. At any rate, LL on 24 hours a day for T/O and Landing is a safety procedure but I suppose some company's SOP's wont call for them or at the pilot's discretion.
Regarding the golf balls- sounds like a file is corrupted in your A.I. somewhere. Maybe someone can chime in here.
NeoMorph
I'll have to take a snapshot when I see it again (maybe buzz a busy field and get a ticket heh).
If you're using TH2GO and Projecting (even on monitors I think so too), this will cause an error with the light sizes, as well as airport lighting. If you're using GEX or UTX (the one that works with lighting) with the above, this will be a problem as well.
You have to change the Halo.bmp file to a smaller version of itself. Imagine the current default Halo being size Large, and after using the aforementioned items, that large doubles in size. So, you need to change your Halo to a small or extra small, then when it gets doubled, it is a large again (so to speak).
Do a search on the Halo.bmp, you'll have no problem finding it. Read the info on it and then decide the size you want and yes, not everyone uses the same size, as some like the lights bigger (not golf balls though) and some like them smaller.
BSD
Ricardo Carvalho
Hello,
As far as i know, at least in europe landing lights are mandatory for aircraft bellow 10000 feet, and when aircraft is on the runway.
NeoMorph
Thanks for the info... I'm very much learning because the last FS I flew was 2004 back when it first came out but then my PC blew up and I went over to console gaming for a while (I know, sad...).
Heck, I couldn't even remember how to do a proper ILS landing with approach hold and glideslope capture... I was doing it all manually heh. I really am going back to flight schoo, it seems...
Heck of a lot of fun though.
NeoMorph
I think either I have a corruption in the graphics or there is a problem with my graphics card. You see, occasionally when I am flying I have "blip" where the graphics go all weird for a second and then back to normal. Strange thing is that it only happens when flying in FSX. When I am playing games like Crysis though it works flawlessly and that game hammers the card a lot more than FSX?
Does anyone else see glitches happen while flying FSX?
