October 17, 2026, 11:36:39 AM
862 Guests, 0 Users
  • Online today: 877
Guests: 862
Total: 862
OC Overhead Annunciator Kits
Started by bussgarfield, May 03, 2011, 03:10:40 AM
bussgarfield
Hi all.
Having just replied to Ian's topic on 7 segment displays, I thought I would just mention a problem that I have encountered to help those that may be undertaking the building of the overhead using OpenCockpit annunciator kits.
Please don't get me wrong, I think the OpenCockpit products are very good but having fixed in numerous annunciators, I have encountered a little problem that could have been eliminated before the instalation.
The annunciator kits come with white plastic pieces that are glued together to form a box in which you insert the LED's at one end and the other is glued to the actual annunciator display. I made up batches of the little white boxes and little circuit boards with LED's attached to fit to them. They were then all glued in place and wired up.
Now this is where the problem arose. I started tinkering with the back lighting for the OH and having got that sorted, switched it on. Surprise, surprise, all my annuciators lit up. The backlighting was actually shining through the white boxes and subsequently showing light through the annunciators. The LED's in the annunciators do over come this but I do not want them lighting up like this when they are off.
So, OpenCockpits, if you read this, it may be prudent to manufacture the plastic parts in black. For any one else considering using the OC kits, I would suggest painting them black prior to the instalation.
As for me, well, I will have to try and get a fine paintbrush in between the wiring to paint them black.
May be of help to a few of you.
Gary Buss
NAX228
Just finished gluing AND painting 101 annunciators from OC last weekend... I painted them before i installed/mounted them and I guess that made things a little easier.
For you guys that is about to start glueing... It's A LOT of glueing :D
