Cessna modified VC view + wings - problem solved
Started by Vectro, May 04, 2011, 08:03:07 AM
Vectro
we are using a modified virtual cockpit view with prop only and on top we have modified 2D instrument panel as a wings:
My problem is that I always have to press SHIFT+1 to add the wings view manually on top of virtual cockpit.
I also attached the same setup with default views before modifications to make it easier to understand our setup.
Is there any way to save the 2D gauge panel on top of virtual cockpit view? After the flight is saved and reloaded the 2D instrument panel has disappeared.
BR,
OP
Vectro
If this kind of window saving is not possible from FS2004 settings, maybe this kind of keycommand combination could be run via FSUIPC instead (by combining SHIFT+1 keys). This way it would automatically load the wings on top of virtual cockpit wing right after the flight have been load.
/OP
Vectro
It seems that I managed to solve the problem. If the background/VC cockpit is in 'maximize window' mode, the 2D panel (wings) cannot be saved and reloaded.
Once I took the 'maximize window' mode off everything is saving and reloading perfectly.
The printscreen is just a snapshot from my home/test computer.
