October 16, 2026, 04:59:03 AM
322 Guests, 0 Users
  • Online today: 849
Guests: 322
Total: 322
Tagging
Started by jackpilot, June 21, 2011, 12:28:18 PM
Still wiring..
Any of you found a neat way to tag cables with info on what it links to?
Someting better than handwriting on masking tape !!  :D
Ive used a dymo label writer in the past. You can set different fonts and letter sizes as well which is great.
Tom_G_2010
I don't know if this would work for your application, but most electronic and electrical supply houses carry wire markers that are made cloth tape.  They have a white background and black numbers or letters.  I've used it on a number of sound system installs.
http://www.grainger.com/Grainger/BRADY-10Book-Wire-Marker-3TP20?cm_sp=IO-_-IDP-_-RR_VTV70300505&cm_vc=IDPRRZ1
I have a neat machine that writes directly on special shrinktube. But... I prefere the masking tape anyway...
Quick, easy and editable  ;)
Jack this is also why we used Network cables. You only have to label the outer wire and then just write down a chart for the colors of the inner wires.
In our case, we used group 1, group 2, group 3, and so on. Thus, we used a Dymo Letter Tag (hand-held) (www.dymo.com). You must use paper tape and not plastic, as plastic will pop apart after a while.
You would only have to label two times per cable. However, if you're doing the twisted wire act, you could just label the bundle, as well as use a marker to write on the back of the MIP and Overhead for location code names; no one will see the markings. Plus, there is no need to label every wire if you keep a good chart...
Team BSD
