July 01, 2026, 03:06:10 PM
70 Guests, 0 Users
  • Total Members: 4,243
  • Latest: Jim738
  • Total Topics: 7,902
  • Online today: 141
  • Online ever: 13,689
  • (May 23, 2026, 05:33:42 PM)
Guests: 70
Total: 70
737 FDS Overhead taking shape
Started by Maurice, August 24, 2011, 02:46:30 AM
Lots of work to assemble but the LED annunciators' wiring took me only one day to finish. Using a tool to add the connectors instead of soldering wires is the only way to go.
Wiring the switches took quite a bit longer because of all the solder connections at the switches, but still, not nearly as bad as I had imagined.
The interface IT SYS board made all the offset assignments a real snap. I still have to add the IBL connections but these are really easy to do.
Very nice!  Is that an FDS OH frame i presume?  If you p/u a real APU egt gauge let me know and I can help you interface it.
jetpilot
Nice job Maurice.
I see you have a real cabin diff press gauge. What is your plan about it?
 :D
Quote from: 727737Nut on August 24, 2011, 02:59:23 AM
No, it's a home made temporary job to assemble the overhead. I have the FDS mounting kit which works with the FDS shell.
Quote from: jetpilot on August 24, 2011, 03:09:20 AM
Nice job Maurice.
No plan for it at all. Jack had an extra gauge which he was kind enough to give me. Just looks better than a fake gauge. Of course, I could always install an air pump to pressurize the shell after sealing all the openings of course  ;D
Looks great Maurice.    What did you use for the Outflow valve guage?  My FDS overhead didnt come with a dummy so I need to fill that hole and was going to use a real one.
Quote from: XOrionFE on August 24, 2011, 06:07:05 AM
My overhead came with a dummy gauge so they might have missed packing it. Steve can probably confirm.
I think Trev has a real one which he is not using so you may want to contact him, but I really don't see the point of having a real gauge here. It is so small as to be barely visible anyway
Great work Mau.
You are now the living proof that assembling and wiring an Overhead can be done in no time at all!
Great inspiration for some of us.
dharrison
Maurice,
Really looking great here! Nice to see it all lit up I bet.
Don
Quote from: dharrison on August 24, 2011, 07:41:27 AM
Maurice,
Don
For sure. And even nicer to be able to start the engines and see all the lights do their thing including some of the blue ones that start bright and then go dim. Very neat indeed.
Oh boy...Don is going to kill me if I dont get going on getting the overhead done
Quote from: XOrionFE on August 24, 2011, 08:46:51 AM
I feel for you. Don't forget I am retired and I don't have 3 little ones running around me and wanting my attention. Frankly, I am amazed you got that far already with your simulator.
But as far as the overhead is concerned, I don't know if you got the tool to add the connectors, but if you don't, make sure you get it & don't even start without it. Without it, I would be weeks away from finishing.
I've got that tool Maurice.  What did you do?  Just pull the existing shorther wires off the connectors and put your longer ones on?
What is the green wiring for on the LEDs?
Quote from: XOrionFE on August 24, 2011, 04:04:39 PM
Not exactly. When I got the overhead, Peter asked me if I was going to get the tool and since I was, I just got the connectors without the wires. I guess you can exchange them or pull the short wires off (I would exchange them if I were you)
The 10 pin connectors to the sys board has 4 white, 4 green wires and a black on pin 1 (ground). The different colours are just to make it easier to identify and wire.
Did you get a sheet named Legend from Steve? It shows the colour scheme.
When you start the job, you may want to phone me as I can give you some good hints to make the job very easy now that I gained experience after pestering Steve  :).
Thanks Maurice
Yes, starting it.   Send me an email with your number and the best time to call.   Would love to hear your pointers.
Quote from: XOrionFE on August 24, 2011, 04:59:52 PM
Thanks Maurice
On its way.
dharrison
I'm not going to kill anybody! :camp:  I am just happy we finally got some flights in with full VNAV (for the most part) working. It was a real treat into LAX on the RIIVR3.
Don
NeoMorph
You do realise that you have released the "Curse Of The Wires" don't you. Five minutes after you leave them alone they will tie themselves into knots it takes a master scout or a sailor to even begin to understand.
:huh:
