Beech Baron 58 cockpit/cabin dimensions
Started by seakem, September 03, 2011, 10:25:29 PM
seakem
Getting ready to start building a flight sim cockpit based on the B 58, when I noticed that I don't have the required dimensions. Can anyone in "Cockpitbuilders" land help me out. Thank you. With a Handshake, Russ
Hi Russ,
Here is a site with some info on the Baron that may be useful . . .  has some dimensions of the instrument panel.
http://www.baron58.com/toc.htm
Hi Russ,
Found another site with some info on building a shell with measurements.
http://home.exetel.com.au/flightsim/fuselage.htm
seakem
Hi Shaneb,
Thanks for the heads-up the sites for info on the Baron.  I'll contact those gentlemen.  Russ
Hi Shane,
On October 1st I take posession of my Beech 99.  If you need some of those dimensions I should be able to help.  I know the cockpit is larger then the 58, but there will be some similarities.
