Need help with Radio settings
Started by boris4356, October 15, 2009, 03:03:07 AM
boris4356
Hi Everyone,
I am trying to set up my radio panel, and I am having some problems. I have read all the FSUIPC manuals and documents quite a few times, and I am making some headway, but I am stuck on the radio settings.
The radio style I want to use is in the attached pic. I cant figure out what FSUIPC settings to use for the top panel Com 1&2, Nav 1&2, and ADF buttons to select the appropriate one for tuning. I tried Com_Radio_Set, Com2_Radio_Set, Nav1_Radio_Set, and Nav2_Radio_Set, but nothing happens. Do I need additional parameters? I have found the proper settings for the Com and Nav tuner swap, and for the tuner knobs.
I have found that the settings for the middle panel Com 1 call and Com 2 call are Com 1 transmit select, and Com 2 transmit select, but I can't find what to use for the equivilent Nav Radio call settings. I have found the MKR, DME, and ADF settings.
Any help anyone can give would be greatly appreciated!
Bill
Hi
maybe for the middle panel the nav buttons could be activated by an ident function ?
It is a curious panel anyway.
Will check later.
Hi Bill
Looking at the radio configuration program from the radio system that my father designed (and from talking to him about it for you), the offsets to use for swapping a tuned standby frequency to an active frequency for the NAV and COM radios is 3123. There are different 'bits' used in this offset for the various functions (e.g. 3123-2 is for NAV2  and 3123-3 is for COM1).
Similarly, the offset for the 'Radio Audio Switches' is 3122 and it uses different 'bits' for each function (e.g. 3122-6 is for COM1)
Here's a screenshot of what the buttons section of his radio configuration looks like.
I hope this helps you out.
boris4356
Thanks for the replies guys.
What I am trying to do, is to just have two tuning knobs for all radio functions using rotary encoders, and then select either Com 1, Com 2, Nav 1, Nav2 with separate switches for tuning the appropriate one. I am able to do this with the attached gauge in the original post, by clicking the mouse on the applicable button and then click on the tuning knob. FSUIPC has established settings to swap the COM and NAV Stby functions, so that is not a problem.
I am not sure if this really can be accomplished by using actual switches, or if I will end up having to go to two tuning knobs per radio function. I don't have enough slots left on my BU0836X card to have two knobs per function, or use dual rotary encoders.
Bill
Go Flight modules can do that.
Their software is incredibly versatile and easy to use.
Check their doc at Goflightinc.com
boris4356
