Annunciators
Started by jonesthesoftware, February 13, 2012, 07:43:55 AM
jonesthesoftware
I've just received my little plastic annunciator boxes from Open Cockpits and they are excellent. However I would recommend that if you use them, fit a diffuser in them to eliminate the "spotlight" effect when using 2 5mm LED's. You can see in the picture I've used 3mm opal acrylic. Incidentally the one at bottom right is a "real" one.
regards
geoff
Building a 767 cockpit
