Help needed finding a part for the Citation Mustang fuel transfer switch
Started by hexpope, March 21, 2012, 05:00:55 AM
hexpope
As the title states, I am looking for a 3 pole rotary switch for the fuel transfer function which uses a 90 degree turn. position 1 = Left transfer, position 2 = Both, posistion 3 = Right fuel transfer. It has to have a 90 dregee switch throw from each selection.
Its the only component thats holding me back from making the panel as I yet don't know the diameter for the hole.
:huh:
hexpope
Great stuff, thanks Phil and shane, I think shane's rotary switch is the one im going to go for.
Thank so much guys  ;D
hexpope
@ shaneB, I am looking at the datasheet for that component, and im wondering is the panel mount hole 3/8" ? as im using millimeters over here, so that would be around 9.5mm ?
I get 9.5250mm for 3/8" and the thread hole on the data sheet is 3/8"  You may want to go to a 10MM hole to be sure it wouldn't be too tight, but Thats just me.
hexpope
Thanks Trev, I was thinking that was the diameter in the PDF I did give about .5 of a MM just to be sure.
