737 évolution
Started by guy737, August 28, 2012, 08:14:48 AM
guy737
Hello, :idiot:
voici l'évolution,
Can you help me,  :huh:
Je recherche les dimensions des windows, les angles d'ouvertures, les largeurs des tablettes de fenêtres latérales, etc... pour placer sur le sidewall.
Amitiés,
Guy
guy737
hello,
New pictures,
roue dentée pour impulsion du trim.
Amitiés,
Guy
Hello Guy,
I believe you should find all the dimensions you need in this site:
http://www.markuspilot.com
guy737
Hello  :idiot:,
next picture...
test éclairage background.
Amitiés,
Guy
guy737
Hello
the last pictures :
Amitiés,
Guy
guy737
Bonsoir à tous  :idiot:,
voici les dernières photos...
Can you give me your opinion?
Amicalement,
Guy
Nice photos Guy.
- The wiring in the first photo looks nicely organized.  Perhaps it is for power distribution.  If so, you might want to consider a Buss Bar approach to this kind of wiring.
- It looks like your main support for you MIP is wood.  Working with wood panels offers a lot of flexibility and can be worked with easily.  You might want to consider adding gussets in some of the corners for greater stability and stiffness.  Fiberglass/epoxy gussets are easily made and do not require an drilling or nut and bolts.  On the other hand, bolting things together allows for dis-assembly if required.
- The Throttle Quadrant looks nice. How did you build this up?  Was it a kit?  What functions does it have?
- Nice profile on the Yoke.  Once you have this Yoke shape completed, you might consider dipping it in an epoxy resin.  Then when cured, you can paint it black for a nice finish.  What functions (switches) do you have on the Yoke?  How is it interfaced to the Flight Simulator software?
Good luck on your 737 sim project.
Keep your airspeed up!
