October 13, 2026, 04:29:51 PM
412 Guests, 0 Users
Guests: 412
Total: 412
Wideview vs TH2Go
Started by mickc, February 25, 2013, 12:23:54 AM
Darn it you guys....
Your going to have me firing up my FSX installations again!   I had all but given up on it and made up my mind but you guys suck me back in.....
markfire
Tried your Wideview settings today Mark using 3 of my 5 computers to begin with and actually worked quite nicely.   I still get jitters on the clients and lag especially when turning while taxiing but better than it was.   I was running in LAS scenery and my framerates where all in the 20-30s on the ground (all systems set to unlimited and Nvidia Inspector set to half the sync using Nick Needham's recommendations).  I havent tried Kostas but I assume they are similiar to Nicks?   Anyway, needs a little more tweaking but liking it so far.  Looking at full FTX Global at 1080p on each 60" display with REX textures is really a site to behold.   Had a nice flight from LAS to SNA in gorgeous sunset conditions with just perfect weather and clouds to fly in.  Sweet...
markfire
#53
Promising stuff. I think you'll get a smoother experience if you use the Kosta tweaks. Mainly, Bufferpools=0, SGSS – Sparse Grid SuperSampling setting (this one is my favourite to kill the shimmering),
Others.  [JOBSCHEDULER]  AffinityMask=14
              [GRAPHICS]   HIGHMEMFIX=1
Also a must if running full screen.
VSYNC TWEAK – FULL SCREEN
A thing worth mentioning here is a new discovery on the Hardware Video Forums about new Nvidia VSync.
This tweak brings unparalleled smoothness with the locked frame rate at 30fps.
In short:
1) identify your monitor refresh, and if it's 60hz...
2) set locked 30fps in FSX FPS and see that you get it!
3) set Nvidia Inspector like mine when it comes to VSync – ½ refresh rate
This tweak only works in full screen. It does not work in windowed.
Here's the link for anyone reading this post.
http://kostasfsworld.wordpress.com/fsx-software-and-hardware-guide/
Weather wise, I'm using FSGlobal real weather, which supports wideview and releases some resources back over to it. I find I get a smoother flight with wideview weather switched off.  You've probably read the posts on here and seen the videos.
Let me know how you progress.
Mark
sluyt050
I can confirm Marks settings for 100%, it's my experience too that they work very well. FSGRW will be implemented soon (quite busy now with finishing my platform and expecting FDS Shell, MIP & OVH panels to arrive soon).
Edward
markfire
Edward
Sounds like a nice pit you're building there.
Are you buying the FDS liners also?
Post some pics of your progress.
Mark
sluyt050
Quote from: markfire on September 15, 2013, 11:46:26 PM
Edward
Mark
I am happy with the results so far and yes liners and rudder panels [captains side only) are included.
I will post my progress in a new topic (as I did for the control columns).
Edward
Mark,
I just wanted to say a BIG HUGE THANK YOU.
I used the Kosta tweaks along with your wideview settings and my wideview setup is now running smoothly and beautifully for the first time.    That combined with the FSGRW weather generation and sync has just brought my whole sim new FSX life.   Combining all that with Orbx FTx Global and regions I have and it is an absolutely stunning world on 5 60" displays.   Weather using rex and FSGRW is amazing.   I have a few more tweaks to make sure textures and settings for FTX and REX are all matched and a few more adjustments to zoom and i think I am all dialed in.
Video will follow.....
Thank you again and I owe you one...
markfire
Great to hear you had some success!  All i did was point you in the right direction : )
look fwd to seeing the video
Mark
Here are a couple more videos with the new settings running around in Vegas Scenery with FS Global Weather.
This is the best my setup has ever run with Wideview and I am ecstatic.  I hope you enjoy.
http://youtu.be/zbauFb1SKy0
http://youtu.be/wJ-3Fc-Vrpw
sluyt050
Thanks Scott, brilliant video. It finally all comes together inclusive real-time weather.
Edward
phil
In the fsx.cfg file, the wideview aspect should this be set to true or false when using wideview ?
And is this the solution for a perfect horizon when turning left or right in the air ?
markfire
phil
Ok thank you, for your 5 tv's are you also using 5 computers for the outside views ?
markfire
Yes. Four i5 pcs for the clients and an i7 for the server/centre view.
sluyt050
Quote from: phil on November 29, 2013, 09:17:46 AM
IMO it should be set to FALSE assuming that you use landscape views. I have a 210 deg. FOV setup using 3 scenery FSX/WideView PC's driving 3 projectors producing a 16:10 landscape image each.
In general (Ref. Windowmaker tool):
If windows are wider than they are tall, set Wideviewaspect=FALSE
If windows are taller than they are wide, set Wideviewaspect=TRUE
Edward
phil
I also thought that it must be set to false. Do you use the virtual cockpit view or the cockpit view without the instruments for the outside views ?
sluyt050
Quote from: phil on November 29, 2013, 04:24:16 PM
2D cockpit view but disabled so scenery only.
Edward
phil
For the zoom settings, isn't 1.00 the best setting for the outside views, i will try it on 3pc's today and 3 screens. If this works then i will 2 more pc's to get the side views.
At this moment i'm running fs9 with 5 tv's on 1 pc, 2 graphic cards, and have the 5 different outside views.
Phil
sluyt050
#69
Quote from: phil on November 29, 2013, 10:59:55 PM
Phil
Your zoom factor is determined by the number of views (5 in your case) and the total Field Of View. Suppose you choose a total VOF of 200 deg. (so 40 deg. per view), your zoom factor becomes: 0.829578719 (calculated by the Window maker tool). The total VOF depends on how you arrange your tv's.
Ref. Window maker tool: http://www.mycockpit.org/forums/downloads.php?do=file&id=469 (you have to logon).
Good luck with your setup!
Edward
markfire
Guys
You are getting confused with projector settings and wideview (the program)
I don't know about Fs9, but FSX should be set to wideview=true when using tv's and multiple pcs
The zoom factor will be around 1.60 for 1920x1080 resolution.
You dont need windowmaker or any other tool than wideview.
I use the Jetstream model that has no VC just outside view.
Believe me, I know!
sluyt050
Quote from: markfire on November 29, 2013, 11:47:20 PM
Guys
Believe me, I know!
With all due respect Mark, but I think I am not confused!
As I said before, I have a 210 deg. FOV FSX/WideView setup running on 3 scenery only clients controlled by a FSX/WideView server. I use 3 x 16:10 1280x800p ultra short throw projectors. FSX Wideviewaspect is set to FALSE. Zoom factor=0.431217809 derived from Window maker. I also use the Jetstream model together with ProSim. I start FSX by means of a saved .FLT file with the correct view angles. Also WideView has to be setup with these angles.
What can I say more? Everything runs fine and my views align perfectly.
Edward
markfire
Yes you are right with using projectors but our friend I believe is using wideview and tv's.
Very different beasts!
I think he has all the info he needs for both setups : )
sluyt050
Quote from: markfire on November 30, 2013, 12:25:44 AM
Hi Mark,
What could be the difference between tv's and projectors in terms of image geometry? I opted for 85" flat projection screens for certain reasons. For me these are just big (relatively bad) tv's.
Edward
phil
Ok i will try to setup the views today, i have 37 inch flat tv screens
Phil
