Question for Scott re: wiring overhead
Started by Sean, March 29, 2013, 07:38:14 AM
Sean
I recall someone on here saying they used a manual tool to terminate their overhead wiring into the FDS SYS board headers. I'm sure it was Scott.
Was it this tool...
... and did it stay good for the entire job? Is the end metal or plastic?
Sean
link: http://media.digikey.com/photos/Tyco%20Amp%20Photos/59803-1.jpg
That is it Sean.  Works great.
Sean
I Think there is a more sophisticated ($$$) crimper for that. Will check for you.
I did all mine manually joining each and every wire to the precut wired terminals ..to be avoided! :D
Sean
You are absolutely right Jack, there is. It's a 2-part device comprising the handgun and the crimp head...
Here is a page with all 3 and the UK prices (if the link works outside the UK)...
http://uk.rs-online.com/web/p/idc-termination-tool-components/1295085/
£197 as opposed to £17.
Which is why I wondered if the cheaper manual tool would be good enough to do potentially up to 432 terminations that exist on the SYS1X. If not, I'd have possibly considered the more expensive tool. But Scott reckons the cheap one will do the job!
Thanks Jack.
Sean
I did my whole overhead and pedestal with the cheap one and worked perfect.    I did cut a little piece of plastic with some holes in it perfect size to set the connectors in on the table to hold them upright without tipping whilst I punch wires in but that is easily made out do a piece of wood even with a little scroll saw blade.   Again, worked perfect and glad I did this rather than try to solder a bunch of wires.   You also want to make sure to use proper 24 awg stranded wire.  22 will work also but I found that the slightly thicker size off 22 is harder to fit into the connectors.  24 is perfect and is what FDS uses.
Sean
Thanks Scott. Also for the heads up with the wire sizes. They don't use AWG over here, but the stuff I'm using, 7/0.2mm, is the equivalent.
Sean
