How to post pictures?
Started by FredK, March 31, 2013, 03:02:25 PM
Okay....I'm stumped on this one.......I've got a story to tell with my recent 737 TQ conversion project, but I can't seem to figure out how to insert images within a posting. Do I need to reference an external hosting source or is there hosting capability within the forum? I can always post the pictures as attachments but the story would flow much better if the images are inserted within the commentary. I do see the "insert image" icon but I cannot figure out how to use it.  I searched the directions but no help there.
Any enlightenment on how to do this would be much appreciated.
Ater you hit reply, there is a + sign under the message box that says attachments and other options, click it and select the pics you want to upload.
That will add attachments which I well may end up resorting to, but my interest is to "insert" pictures within the posting.  Others here have done it and there is an "insert" icon so there must be a way.
Here is a pic I did through the attachment too see if it post correctly...
Hey Fred,
Are you pics of the correct type? Read the type list by the attachment browse button. The one above is a .jpg and it is showing within the post.
Edit: Unless you're intending to post the pic(s) as fullsize photos without the linking and smaller image representation; if that's what you mean, then I don't know...
Hello Fred,
Yes, you are on the right track.  You need to host your pictures somewhere else then you can place links to them with the insert img function on this site.   I use Yahoo Flickr photo sharing and you can get a certain amount of space there free before you have to pay.   There is also Google and others.   Once you have the photos hosted somewhere else then just past the link to them.  I believe you could also do that here just by uploading to the file library then posting the links as img links.
Hope that helps.
Sean
The way I understand it, Fred wants to have his pictures inserted into the text, so he can tell a story, rather than upload them as attachments, which show at the end of the post.
Like this...
Random image...
blah, bla, blahdy, blah...
Another random image...
In which case, you need to use the image tags like Scott explains. You may be able to host them on cockpitbuilders.com, but don't upload them as part of the thread. Upload them to the picture library first, then use the address to the image inbetween the image tags. Make sense?
Sean
Fred,
You see the little image icon located above the reply text box (once you click reply to post), it looks like a Mona Lisa (next to the red F flash icon?) Click that img icon and you'll get bracket img bracket bracket /img bracket (actual brackets will be seen, not the words). Now place your image's location url address like http// colon www dot wherever dot com (use the actual characters not words for colon and dot) in the middle of the two imgs; the cursor will be where you need to start typing once you click the img icon...try it and you'll see. Now, your image will be linked...once you finish and hit post/save for the reply.
Fed, Also you can Post the pictures (UNDER THE MEDIA TAB) at the top of this page..  upload your photos there, and reference them in the post.
use the {img}picture address here{/img}  But replace the {} brackets with [] Brackets.
Additionally, each image you upload here to the server gets a unique "smg id" and you can post the image like this...
{smg id=465} again.... replace the { } with [ ]
Here is a How To (with screen shots) I did a while ago for a different site. Photobucket has changed theire layout, but the process should be the same.
http://forums.flycav.com/index.php?/topic/872-how-to-post-pictures/
Thanks to All!
My conclusion is that one needs to source from an external hosting site or into an album here from an external hosting site.  That was my suspicion. Not a problem...will do that.  I just thought there might have been a way to insert images directly.
Fred
