How to connect a gtx 580 to DP TH2GO
Started by baudie, April 02, 2013, 10:31:24 AM
baudie
I don't know how to connect a Matrox TH2GO DP to my GTX 580.
I thought it would be easy, but neither the DVI or mini-HDMI (I think it is) is easy connected to a displayport on the TH2GO.
Any help would be appreciated,
Best regards
Baudie
tote_320
baudie
Thank you for your answer, but I heard that they only work from DP to DVI and not from DVI to DP. Something about passive adapters only work from DP to DVI and that an active one is needed for DVI to DP.
That is why I consider using the mini-HDMI, but can't see cables going from mini-HDMI to DisplayPort.
Are you 100% sure a passive DP to DVI will work?
Best regards
Baudie
