OpenCockpits CDU with FSUIPC issues - please help
Started by bratwurstdimsum, July 20, 2013, 06:56:55 AM
bratwurstdimsum
Hi everyone, I normally lurk around the classifieds looking for a bargain and I certainly got one.  An OC CDU v1.00 for $400.
I have connected it up now and its running on my alienware laptop with FSX, FSUIPC, and SIOC running but for some reason the device status reads "Stopped".  (see attached)
I don't have project magenta nor do I have FDS and I'm trying to run this on a project wilco a330 add-on but all I get is my 2nd computer screen appearing on the CDU but no CDU readout.  FSUIPC does not register the CDU at all as a device (no clicks on the CDU are picked up by fsuipc)
I also am running it with the default script (magenta) as I don't have the first clue about setting a script for Wilco.
I ran the USB check and modified the sioc.ini file as appropriate to my device number #312
Have I really missed something here?  Does OC hardware need PM or FDS as a prerequisite?  is the OC not as "plug and play" as, say Goflight hardware?
Sorry for sounding like a first class Noob - please, any help or opinions are appreciated!
Jeff
THese devices have no software. THey are nothing more then a computer screen and keyboard. You have to have software to interface with them. So as this is an OC unit you would need to open the FMS screen in the aircraft you are using in a window, and then move that window to the FMS screen and then would need the SIOC script to run to get the keys to work on your software. The script "programs" the keys to work. Hope this helps a little. As I do not have the FMS you are using I can be of no more help then this.
bratwurstdimsum
Hi Bob, thanks for your quick reply, that certainly helps my understanding.  I just want to check though if you know whether the "device stopped" status relates to my lack of a suitable script or does it point to something else?
Quote from: bratwurstdimsum on July 20, 2013, 07:21:15 AM
I am not familiar with SIOC or OC hardware so I do not know the answer to that question. I would think you my be right, but again I am not sure.
saabpilot
It stops because you do not have a compatible program that it can talk to.
The CDU is a dumb terminal that makes it possible to access e.g. Project Magenta or ProSim737 software CDU:s through PM offsets.
It "may" be possible to use it against some other FS aircraft with CDU systems IF you load the correct SIOC script.
However you have to see in the documentation, or ask OpenCockpits support.
Bjorn
Sent via Tapatalk.
Fly Safe - Low and slow
There is nothing wrong with your SIOC screen saying "stopped", it matches my own when I plug in my OC FMC.
I suggest that you load SIOC, click on IOCPCONSOLE then select "Log on". If you then can see key presses within the Log window then your key matrix would appear to be ok.
As Bjorn says you need an avionics package or FSX plane addon with CDU functionality and access to its internal commands. You then need a sioc script that is specifically written to link to the avionics package and or addon plane. There are scripts for some 737 addons eg PMDG, but I have no knowledge of Airbus. Perhaps someone else can help here.
bratwurstdimsum
Thanks guys.
I will try the log on later - I'm just a bit surprised as I assumed that, like my throttletek unit or my goflight MCP, FSUIPC would be able to just detect key/button presses and I would be able to begin mapping those immediately.
Any airbus help would be great :) I am in the market for a new addon sim.  Wilco airbus has just about run its course with me.
bratwurstdimsum
  • Okay I changed the USB the CDU was plugged into - it is now in device #318
    I loaded SIOC, then IOCP and pressed the log on.
    It connected but when I started typing on the CDU nothing seemed to register - I put the mouse in each field then typed to make sure but nothing happened.
FSUIPC will not provide you with a working CDU. You must have an avionics package eg Sim-avionics or Prosim (for 737) or an addon plane that has the cdu function AND allows access to its command structure
Your screen shot of the IOCPCONSOLE actually shows that the Log function is turned off, however, I assume that you had it turned on but no cdu key presses were displayed. I also assume that you changed your sioc.ini file to reflect the new device number of 318
I attach a 737 cdu script which should run and show the key presses in the log window. Just copy this text below, save as fmc.txt  in your SIOC directory,  and  remember to change the file entry in the sioc.ini file to match ie CONFIG_FILE=.\fmc.txt
This should prove that the cdu works ok in hardware terms
Var 0000, Value 0
Var 0001, Link FSUIPC_INOUT, name k, Offset $5332, Length 1 //
Var 0010, Name Exec_Status, Link FSUIPC_IN, Offset $5333 length 1
&Exec_led = &Exec_Status
Var 0011, Name Msg_Status, Link FSUIPC_IN, Offset $5334 length 1
&Msg_led = &Exec_Status
// Var 0012, Name Dspl_Status, Link FSUIPC_IN, Offset $5335 length 1
// &Dspl_led = &Exec_Status
Var 0013, Name Ofst_Status, Link FSUIPC_IN, Offset $5336 length 1
&Ofst_led = &Exec_Status
Var 0014, Name Fail_Status, Link FSUIPC_IN, Offset $5337 length 1
&Fail_led = &Exec_Status
Var 0015, Name Exec_led, Link IOCARD_OUT, Output 47
Var 0016, Name Msg_led, Link IOCARD_OUT, Output 44
// Var 0017, Name Dspl_led, Link IOCARD_OUT, Output 45
Var 0018, Name Ofst_led, Link IOCARD_OUT, Output 46
Var 0019, Name Fail_led, Link IOCARD_OUT, Output 43
Var 0002, name key, Link USB_KEYS
if &key = 71 // menu
&k = 160
if &key = 79 // Init Ref
&k = 150
if &key = 78 // rte
&k = 151
if &key = 75 // des
&k = 154
if &key = 70 // legs
&k = 156
if &key = 67 // prog
&k = 159
if &key = 63 // n1 limit
&k = 155
if &key = 62 // fix
&k = 161
if &key = 77 // clb
&k = 152
if &key = 76 // crz
&k = 153
if &key = 69 // dep
&k = 157
if &key = 68 // hold
&k = 158
if &key = 66 // EXEC
&k = 13
if &key = 55 // Prev Pg
&k = 162
if &key = 54 // Next Pg
&k = 163
if &key = 7 // 0
&k = 48
if &key = 32 // 1
&k = 49
if &key = 31 // 2
&k = 50
if &key = 30 // 3
&k = 51
if &key = 24 // 4
&k = 52
if &key = 23 // 5
&k = 53
if &key = 22 // 6
&k = 54
if &key = 16 // 7
&k = 55
if &key = 15 // 8
&k = 56
if &key = 14 // 9
&k = 57
if &key = 8 // .
&k = 190
if &key = 2 // slash
&k = 191
if &key = 6 // plus minus
&k = 109
if &key = 3 // Delete
&k = 46
if &key = 4 // SP
&k = 32
if &key = 1 // Clr
&k = 253
if &key = 61 // A
&k = 65
if &key = 60 // B
&k = 66
if &key = 59 // C
&k = 67
if &key = 58 // D
&k = 68
if &key = 57 // E
&k = 69
if &key = 53 // F
&k = 70
if &key = 52 // G
&k = 71
if &key = 51 // H
&k = 72
if &key = 50 // I
&k = 73
if &key = 49 // J
&k = 74
if &key = 29 // K
&k = 75
if &key = 28 // L
&k = 76
if &key = 27 // M
&k = 77
if &key = 26 // N
&k = 78
if &key = 25 // O
&k = 79
if &key = 21 // P
&k = 80
if &key = 20 // Q
&k = 81
if &key = 19 // R
&k = 82
if &key = 18 // S
&k = 83
if &key = 17 // T
&k = 84
if &key = 13 // U
&k = 85
if &key = 12 // V
&k = 86
if &key = 11 // W
&k = 87
if &key = 10 // X
&k = 88
if &key = 9 // Y
&k = 89
if &key = 5 // Z
&k = 90
if &key = 56 // LSK 1L
&k = 112
if &key = 64 // LSK 2L
&k = 113
if &key = 72 // LSK 3L
&k = 114
if &key = 80 // LSK 4L
&k = 115
if &key = 88 // LSK 5L
&k = 116
if &key = 87 // LSK 6L
&k = 117
if &key = 86 // LSK 1R
&k = 118
if &key = 85 // LSK 2R
&k = 119
if &key = 84 // LSK 3R
&k = 120
if &key = 83 // LSK 4R
&k = 121
if &key = 82 // LSK 5R
&k = 122
if &key = 74 // LSK 6R
&k = 123
bratwurstdimsum
That worked very well thanks!  I also found that soicmonitor which is built in v4 also logs the keypresses.
I'll keep posting here about how I go as I haven't found a thread on this forum that discusses the FMC on its own.  Thanks for preventing me from putting this straight for sale again!   :idiot:
Jeff
Phil64
Hello Jeff,
First, I'm glad you received the FMC in good condition.
For what are the software, I did work with Prosim (free version) in July 2011 and it worked perfectly with the default 737 and Posky. If you want I'll send you the version of Prosim. This has changed dramatically today, but you have to invest.
Of course we also need SIOC FSUIPC. Prosim has a script dedicated to Opencockpit in its software.
Cordially.
Phil64
bratwurstdimsum
Hi there Phil,
Yeah I got FSUIPC and SIOC up and running. Thanks to you I also located that opencockpits file in the prosim737 folder - my FMC now works!  All I have to do is find a compatible plane.  My goal is to have a 737 and an airbus operate off the same FMC.  Will attach pics later
Jeff
bratwurstdimsum
#12
Testing... My tapatalk won't display more than page one of this forum :(
bratwurstdimsum
Hmmm can't seem to get the standard FSX 737 to respond to the data from the FMC
I started a new thread:
http://www.cockpitbuilders.com/community/index.php?topic=3541
