October 18, 2026, 06:45:04 PM
595 Guests, 0 Users
  • Online today: 1,142
Guests: 595
Total: 595
Sioc throttle code
Started by bindook, August 29, 2013, 04:45:09 AM
bindook
Hi guy's,
              I need some help getting my throttles working properly. At the moment the throttles are idling at 42 N1  which is to high.
How do I get them down back to 21 N1 ?
I have read the tutorial for it but cant workout how you get the number 2 for this line
IF V0015 <= 2
At idle throttle 1 is at 73 & throttle 2 is at 51
Below is the current code i'm using;
// Engine 1 Throttle lever
Var 0015, Link IOCARD_ANALOGIC, Input 03, PosL 27, PosC 139, PosR 252 // Throttle 1
//Var 0015, Link IOCARD_ANALOGIC, Input 01, PosL 30, PosC 106, PosR 236 // Throttle 1
   IF V0015 <= 2
      V0081 = -4096 // Idle
   ELSE
      L0 = v0015 * 64.25 // 16384 / 215
      IF L0 > 16384
         L0 = 16384
      V0081 = L0
Var 0081, Link FSUIPC_OUT, Offset $088c, Length 2 // Engine 1 Throttle lever, –4096 to +16384 = 20480 range
// Engine 2 Throttle lever
Var 0016, Link IOCARD_ANALOGIC, Input 04, PosL 5, PosC 119, PosR 234 // Throttle 2
//Var 0016, Link IOCARD_ANALOGIC, Input 02, PosL 0, PosC 177, PosR 255 // Throttle 2
   IF V0016 <= 2
      V0082 = -4096 // Idle
   ELSE
      L0 = V0016   // - 40  off-set
      L1 = L0 * 69.42 // 77.28  16384 / 212
      IF L1 > 16384
         L1 = 16384
      V0082 = L1
Var 0082, Link FSUIPC_OUT, Offset $0924, Length 2 // Engine 2 Throttle lever, –4096 to +16384
Michael
FSX, Jeehell, Fly-Elise
Hi Michael, I reckon you should bin that SIOC and fit a BU0836X card to solve all your issues. I have a spare card at home if you want to try it out. I use them on all my interfaced products with Leo Bodnar's approval. Set up will take you at least two minutes!!!
Cheers Gwyn
bindook
  Got it going Gwyn, played around with the code & she idles properly now.
Thanks for the offer but will stick with sioc  as its all working for now.
Michael
Fair enough, I'll have to come and have a look soon...
I may be wrong somewhere but seems to me a TQ can be very simply calibrated with FSUIPC and a simple joystick card  (including reversers,spoilers, flaps, parking brake and FCOs) withourt any programing! :2cw:
Correct, but if you want throttle levers working under A/T, automatic spoilers and trim wheels moving in direct response to actual trim then I believe that you need some programming control
bindook
Gwyn ,
            yr welcome to pop over but will have to put that visit on hold, just bought a house in the vines . Move in on the end of November.
