October 15, 2026, 03:14:09 AM
430 Guests, 0 Users
  • Online today: 914
Guests: 430
Total: 430
Arduino and FSX
Started by Sam Franklin, September 22, 2013, 01:32:40 AM
Sam Franklin
Hi guys,
Somebody, a few weeks back, recommended I look into Arduino as a micro controller board. I did and it should be arriving next week. I've been searching around but can't find out how you can get FSX/FSUIPC to detect the axis? Is there some way to make the output from the pots be detected by FSUIPC?
Sam
Caflyt
Sam,
Take a look at this link. I have successfully converted two Arduino Uno's and one Mega in the past and they work pretty well. I have never used one for pots but I understand that they work just fine. I used Arduino boards for my generic build a couple of years ago and they did an acceptable job for the type of build I did. There is a learning curve to programming them but it is not quite rocket science and my little pea brain was able to absorb just enough to get them functioning as I wanted them to at the time. For a larger scale build, they are not the optimal solution but for a smaller setup they are fine.
http://fredgolden.com/Recipe_for_a_cheap_joystick_encoder.pdf
Also take a look at this guy in New Zealand who has done quite a bit with Arduino and FSX/FS9.
http://www.jimspage.co.nz/link2fs_inout.htm
Hope it helps!
Craig
