A320 Family Speed Brake/Flaps Levers
Started by Sam Franklin, September 22, 2013, 11:05:07 AM
Sam Franklin
So if I'm going to build this speed brake lever (and flaps)  I've found out that it's best to use a pot and assign the zone for each position with FSUIPC. I'm just wondering how can I create it so the lever only goes in the RET, Half and Full positions and not just sit in between and the same for the flaps but obviously in the various positions.
Sam
You need "gates".
you may find your own way to do it by using basic hardware.
You may use springs to hold levers down in a notch.
(See diagr.)
Also, use sliders instead of rotary pots . that way you do not need gears (See diagr.)
Plungers are also handy, see pics.
Sam Franklin
Hi jack!
Invaluable help again. What are the name of those plungers? I can't find anywhere to buy them!
Sam
http://www.fastenal.com/web/products/plungers-and-accessories/_/Navigation?term=plungers&termca=&termpx=&sortby=&sortdir=&searchmode=productSearch&zipcode=&filterByStore=&filterByVendingMachine=&r= ~|categoryl1:"601071 Cutting Tools 9and Metalworking"|~ ~|categoryl2:"601114 Tooling Components"|~ ~|categoryl3:"611287 Plungers and Accessories"|~
Check for a Fastnal store in the UK.
