Need help with interfaceIT to IFlyToFsuipc (on JetMax system)
Started by jeffbboat, September 26, 2013, 03:11:11 PM
jeffbboat
Can anyone offer a suggestion? I have the JetMax737 cockpit and iFly Pro Cockpit Builder for FSX running on a Windows 7 PC.
I start FSX.  Load an iFly 737. Start IFlyToFsuipc. Start interfaceIT. Import the FSUIPCOffsets.xml.  I see a Module load message scroll across FSX.  The LED test in interfaceIT works - all LEDs light up. But then nothing works - no switches or lights on the cockpit do anything when pressed/toggled/rotated/etc. When I exit out of interfaceIT, a module unload message scrolls on FSX.  It acts like iFlyToFsuipc is not picking up the commands and sending them to FSUIPC.  Any help or suggestions would be appreciated.
Jeff
Jon Boe
Hi Jeff,
When you load the xml file into interfaceIT are you saving the imported offsets?  (Clicking the disk icon at the top of interfaceIT).  Also, after you load the card if you look at the individual inputs and outputs in interfaceIT are you seeing the specific offset names displayed?
Jon
