October 23, 2026, 06:28:09 AM
264 Guests, 1 User
  • Online today: 524
Guests: 264
Total: 265
Engine surge during jet engine start
Started by Mach7, September 28, 2013, 06:04:37 AM
Mach7
I know this is a flight sim thing...but is there anyway around the unrealistic engine 'surge; of N1 and N2 during a jet engine start in fs9.
there must be a patch to fix this?
You need an avionics soft on top of FS, (PM SimA Prosim etc..) which allows slowing down spool up and adjusting the N1 N2 sequence.
I doubt you can modify stock FS.
Mach7
Thanks jackpilot...guess i will just have to live with it.
Maybe a LUA using FSUIPC could do it.
Maybe David (FordGT40) or Mike would know
Guys? ::)
I am away for a few days, but will think about it. If the OP could specifically define what is wrong, eg wrong sound wav, timing, sequence etc, it would help
James
Please keep contact with David on that
Pretty sure he can find a way!...lol
Mach7
Guys, thanks for taking the time to look at my problem.
Here is a link to my engine start video (tried to download it here but the file was too big).
http://s794.photobucket.com/user/Mach73/media/BAe146_gauges/001.mp4.html?sort=3&o=0
Dave, as you can see I am trying to eliminate or reduce the N1 and N2 surging past the ground idle values during engine start, that is to say they should accelerate normally to 26 percent and 51 percent repectively.
I know this is an inherent Fs9/X thing, and also realize that some simulator platforms (payware) have probably solved this problem, but was wondering if there is something I can do at this end to fix this.
Thanks again for any input
-Jim
Mach7
Also...sorry for the video quality, starting from the top the gauges are as follows, Oil temp/press, N1, TGT, N2, and Fuel flow (WF).
Jim
What software are you using to drive the gauges?
If it is SIOC, could you post the script
No pressure then  :D
Mach7
David,
I am using SIOC.
Here are two of the scripts, one for Engine 1 N1 and the other for Engine 1 N2;
// * Config_SIOC ver 4.01   -     By Manuel Velez    -    www.opencockpits.com
// * FileName : EngineGauges.txt
// * Date : 05/03/2012
Var 0001, name Eng1N1, Link FSUIPC_IN, Offset $0898, Length 2     // Engine1 N1
  L0 = &Eng1N1 / 164     //  Scales to 0-100%
  L1 = L0 * 5.24
  L2 = 314 + L1
  &Eng1n1servo = L2
Var 0002, name Eng1n1servo, Link USB_SERVOS, Output 1, PosL 314, PosC 576, PosR 838
Var 0017, name Eng1N2, Link FSUIPC_IN, Offset $0896, Length 2     // Engine1 N2
  L0 = &Eng1N2 / 164     //  Scales to 0-100%
  L1 = L0 * 5.37
  L2 = 322 + L1
  &Eng1n2servo = L2
Var 0018, name Eng1n2servo, Link USB_SERVOS, Device 1 Output 3, PosL 322, PosC 591, PosR 859
Jim
Thanks, I have family here at present, but will look at this later
#11
Hi Jim
I have had a look at the problem. Given that we cannot get into FS then we need to look at the sioc coding for the gauges to see if we can limit the
needle movement so that the "surge" is not reflected by the needle.
If we create a variable called startup and set this to 1 when the code is first run, then we can use this as a flag to see whether we need to limit the
needle movement; eg if we are in "startup" mode or not.
We can then insert some code into each engine/gauge code so that the needle movement is limited, but only when in "startup" mode.
Suggested code changes are: -
Var 0, value 0
&startup = 1 / flag set to 1 to show we are in startup mode, only use this code once at the beginning of your script
Var 10, name startup
  L1 = L0 * 5.24
  L2 = 314 + L1
IF &startup = 1
   IF L2 > xxxx / you need to set this value of xxxx so that the needle relfects the correct idle position
      L2 = xxxx
  &Eng1n1servo = L2
This code if unchanged will keep the startup flag as 1 and will not allow the gauge to move beyond idle value. You therefore need to use another
variable to reset the startup flag back to 0. A suggestion could be to include a line of code that recognises when the throttle lever is moved beyond idle
position, then you can reset the startup flag back to 0 and the gauges will be free to move.
This is simple untested code, which should work, I hope, but will need to be amended if you want the sophisticated functions of engine restart in flight
etc  :)
Hope this helps, any queries then just ask
Mach7
David,
Thank you very much for this...when I get home from my pairing I will try the code out and let you know...i might have some questions before hand.
-Jim
When I met you at the FDS open house you looked like a normal human being.
The way you can figure out  that SIOC stuff out makes me think you're not :laugh:
Thanks for the help.
PS I sent your breakers in the US
Thanks for the CB dispatch - I still owe you!
We have not heard from Jim yet, so the code may not have worked - quite common first time  :)
Don`t worry, I think I am quite normal, or at least as the Mythbusters say " I introduce my own reality"
Whilst I can programme, of sorts, copious amounts of alcohol, good food and bad women are also very welcome and a necessary addition
Is that more normal  :)
Mach7
Hello David and Jackpilot,
Just to update you, I have not had much time to run the program but am planning to do it on one gauge only to see how it works...assuming I can get the SIOC program to compile "OK".
My only concern is with the gauge itself...I am using the actual potentiometer from the actual gauge and if the gauge goes off the scale...i have to unfortunaltley remove the gauge...take it apart, and manually move the needle so the pot contacts are back within there operating range.
i don't anticipate any problems..but will test it out on one gauge first then see what happens..
will keep you updated..
thanks for thinking about me:)
