i was wondering if anyone used this forward/after uppper panels with this card.
Started by pelgrin21, October 05, 2013, 01:20:22 PM
pelgrin21
below is the forward and after panels that i like to use with the fds card i was wondering if they will work toguether.
im building a 737 for ifly also in the future i would like to use Project magneta and sometimes pmdg the hardware im going to use allows me to do all that maybe not the overhead panel but if its compatible ill work with Pm as well.
DIY KIT of AFT Overhead panel
http://symulatory.com/strona/index.php?page=shop.product_details&flypage=flypage_images.tpl&product_id=47&category_id=56&option=com_virtuemart&Itemid=56
DIY KIT of Main Overhead panel
http://symulatory.com/strona/index.php?page=shop.product_details&flypage=flypage_images.tpl&product_id=48&category_id=56&option=com_virtuemart&Itemid=56
FDS-SYS1X High Capacity 128In/256Out Card
http://www.flightdecksolutions.com/components/interface-it/fds-sys1x-high-capacity-128in-256out-card/
markfire
Hi
Just a quick heads up on the IFly 737. Most hardware is compatible, but you'll need the cockpit builders edition for the Mip displays. IFly uses it's own logic and is not compatible with PM, Prosim etc. Personally, I would choose the software I want to use (Prosim, PM, IFly etc) and then stick with the 737 flight model that is most suited for use with that software. All hardware has its plus and minuses regarding compatibility but I personally think you can't beat Prosim at present. Just about any combination of hardware is supported and is expanding by the week. I believe the FDS cards are fully supported.
You should be able to use any in/out cards with the panels you mention, it's all about how much money you want to spend : )
Good luck
Mark
