For those who use Wideview, a few questions.
Started by ak49er, December 03, 2009, 08:05:32 AM
ak49er
I am replacing my TRC 172/Simkits panel with two 17" LCD's. I am using FS9 with Mindstar Aviations G1000 Panel Software.
The G1000 PFD and MFD are "undockable windows."
My first thought is to have the FS9 server run the visuals via a projector, and then with another computer, use Wideview to run another instance of FS9, to display the "module" type software of the G1000.
On this second computer I would have a video card with one signal going to a primary display, and the other going to a secondary display, which is then split into two.
This way I could "undock" and "drag" the PFD and MFD seperatle onto each screen for optimum positioning. the primary display on this configuration could then be a side view or....
Any other ideas?
FS9, FSUIPC, WideFS, FreeFD
XPlane XUIPC, WideFS, FreeFD
Well  Ak, that is one heck of an interesting IDEA... Although I would suggest your Main PC be just the G1000, and use the wideview for your forward view.
Just my thought.
Sounds like you have put a lot of thought into that.  Let us know how it works out.  I don't run Wideview... but I am sure Mike or others can chime in here.
I don't know that that would work on a client machine. The client will display an instrument panel, as I have to eliminate them on all the computers before a flight. This is because the Wideview switch is installed into the cockpit view and must be momentarily visible to switch it 'on', then can be eliminated with the 'W' key.
Anyway, the panels act as though the client aircraft is not moving, running, or doing anything actually. Wideview just drags the outside view along for the ride with the server.
I don't want to say it will not work. Far be it for me to believe anything is impossible in this hobby.
I'd experiment with it, but the way I understand Wideview is that you would have to start up the client aircraft that is using your guage file and have some way to input data to the client to get the instruments to respond.
Like I said, WidevieW just drags the outside view along for the ride with the server in slew mode. I don't think it's capable of anything else.
All I am sure of is that IVAO software will work on a client.
