SIOC to FSUIPC Button (resolved)
Started by rs3tier, April 17, 2014, 09:07:29 PM
rs3tier
Hi Guys
I am hoping someone can give me a little help getting SIOC to fire a Joystick button in FSUIPC.
I currently have a button configured in FSUIPC - and when I press it it shows up as Joy# 0 and Btn# 3 (so button 3 on Joystick 0).
I have the following SIOC script which I am trying to get to emulate pressing this button but it does not work.  I am not sure but my feeling is I am using the wrong offset ($3340) as most things I have read suggest this offset refers to Joy# 64
Can anyone tell me what offset I should use for Joy# 0 - or otherwise see what might be wrong with this script??
// * FileName : XPNDR.txt
// * Date : 18/04/2014
Var 4001, name I_R_STB, Link IOCARD_SW, Device 5, Input 0
  IF &I_R_STB = 1
    &command = 955
Var 4002, name I_R_ALT, Link IOCARD_SW, Device 5, Input 1
  IF &I_R_ALT = 1
    &SaitekYoke = CHANGEBIT 3, v4002 // toggle bit 3 of joystick 0
Var 5000, name command, Link FSUIPC_OUT, Offset $9400, Length 2
Var 5001, name SaitekYoke, Link FSUIPC_OUT, Offset $3340, Length 4
dc8flightdeck
I did this by first creating a custom offset in FSUIPC assigned to the corresponding button, then wrote SIOC script to respond to the custom offset.
In the B-52 sim this is how I used to SIOC Sounds for actions like the bomb bay door transition sounds.
rs3tier
Sorry, I should have updated this post.
I found the solution eventually - which really just involved unmasking my own stupidity.
I assumed I actually had to use a real joystick button to act as a "place holder" of sorts.  Once i realised the virtual joystick just meant that I could treat one of the SIOC inputs as they joystick button, then everything started working beautifully - it got detected as Joystick #64, button 0
