October 16, 2026, 03:30:11 PM
524 Guests, 1 User
  • Online today: 849
Guests: 524
Total: 525
My 737 linked yokes build - yokes completed!
Started by Flying_Fox, April 23, 2014, 07:11:50 PM
Well, my 737 linked yokes build practically completed and ready for install into sim.  :)
compare to this previous photo:
Main recent development was the actual yokes installation. I bought the yokes from aviasimulation.com. They are 100% copies from 737 yokes and made from hard plastic (same as goes for construction hats).
Here is the picture the yokes during production process.
The yokes I have received have all switches are fully wired and have backlighted trip counters.  Excellent quality. I am very happy with this acquire.
Here are the pictures:
Trim switches are separate:
Trip counter backlighting feeds from 12v.
I also got some other stuff from aviasimulation.com:
I finished the outer housing for yoke columns - they are made from standard 3" ABS pipes. Outer housing is only decorative and does not have any structure supporting functions.
Here is the insert I made to install the yoke on my column:
Here is how I completed the yoke wiring:
The existed yoke wires went into a small PCB panel where I added those green connectors. Then the wires go from the green connectors to standard CAT5 network connector:
The installed network cable goes in between the actual yoke column and outer housing. Ground wire is separate, as there are only 8 wires in CAT5 cable.
Will post more details later in my building thread.
:2cw:
Ingenuity at work !
Well done Nick..as usual.
