Just Wondering About Ground Services
Started by Andrew 737, May 14, 2014, 11:09:07 AM
Andrew 737
Hi Guys
Has anyone ever used AES in a Wideview  configured system?
The system is 4 pc's - 1 server, 3 wideview clients for scenery. Just wondered if anyone could give me a heads up before I go installing?
The main problem is how to get multiple copies of AES running at exactly the same time.
Regards and Thanks
Andrew
Andrew 737
Really?
You pioneers out there - has no one done this!
Regards and Thanks
Andrew
Sorry Bud, I don't know anyone doing that.
Andrew 737
Hi Trevor
No probs - I thought it may be a big ask.
The whole ground services thing is really entertaining.
Thanks anyway :)
Regards and Thanks
Andrew
Hi Andrew,
So, what happens when the default tow truck/pushback tug in FSX shows up or works in your setup?
Andrew 737
Hi John
The defaults work - there is the option to sync them via WideView. I don't use airport vehicles though, because they pop up here and there rather than just at my plane. This impacts Perf a bit.
Regards and Thanks
Andrew
Sean
Have a word with Ian Sissons. Last time I was there, he was using AES with wide view. It was a while ago and things may have changed, but I recall not liking something about it (can't remember what!).
Andrew 737
Quote from: Sean on May 17, 2014, 12:05:35 AM
Hi Sean
Wow thanks for this, I don't know Ian (I know of him) so I will wait and hope he reads this post.
Thank you for the input - greatly appreciated.
Regards and Thanks
Andrew
Sean
Drop him an email, he's really loves helping people out. Drop my name in if you like.
Andrew 737
Regards and Thanks
Andrew
dc8flightdeck
#10
Ive never tried AES, but did the same on a network with GSX ground sevices. It syncs fine over the network, but some of animation is lost on the clients.  The marshaller is rigid and no longer has moving arm or legs. The turn signals dont work on the follow me truck.
But it much better with GSX than without it. I used a voice recognition program for the interface. On the FO audio panel, selecing ground intercom disables the headset and hand mics communication to PilotEdge and changes the mics to interface with the voice recognition software for controlling GSX.
The other issue is, you have to configure the voice software for a specific parking spot before the flight starts, so its limited to one parking selection at the end of a flight.
I just realized I dont have video of us talking to GSX, but here is a link to an old out of date video that shows a bit of GSX being used with button activation in the cockpit.
http://youtu.be/9hotit9vwUU
Andrew 737
#11
Hello
I'm talking about running 3 instances of either GSX or AES at the same time.
Regards and Thanks
Andrew
rhysb
Andrew,
On your AES request. I will give you a simple answer: It can't be done! You can't get AES to work or sync on multiple machines.
Ian Sissons only has AES running on the forward view so if you taxi at an airport you cannot see the marshallers or any AES vehicles except in the forward view.
Sorry to disappoint you but have explored it all myself.
Rhys B
Andrew 737
Quote from: rhysb on May 18, 2014, 12:42:01 PM
Andrew,
Rhys B
Thank you for the info Rhys - greatly appreciated
Regards and Thanks
Andrew
Sean
That's what I remember about Ian's. The traffic disappears once it leaves the front view.
Bugger me, now i'm going to have to set fire to it because the views dont 'cut the mustard' :)
The only real way to do this is to set up multiple views by adding
extra video outputs and setting these up as forward/left and forward right.    Then that way you will not loose the traffic.
Rgds
Ian
dc8flightdeck
#16
Quote from: Andrew 737 on May 18, 2014, 12:08:28 PM
Hello
That is exactly what I did with GSX. In the video the pushback sequence is all GSX on wideview.
The video I posted is showing GSX on a 4 computer network with wideview. The simulator in the video has a server running but not visually displaying GSX because the two server monitors are displaying the HSI and radar screen repectively.
When you see the bus, baggage carts, and marshaller in the video, all are being displayed on wideclient computers. The left monitor is client #1, center three monitors client #2, right monitor is client #3. I have a copy of GSX on each of the 4 computers and as you can see in the video it works over wideview, but the video doesnt specifically show is how GSX looses some of the animation features that I previously described.
So in summery, GSX does work over a network, but with some animation lose. The ground service vehicle are visible across all the wideview computers as they drive around. I wouldnt fly without it.
Andrew 737
#17
Quote from: dc8flightdeck on May 19, 2014, 03:56:44 PM
Hello
Hi Justin
Very interesting indeed - I have a few questions if that is ok?
Where is the video to which you refer buddy?
How do you instruct each copy of GSX to run at precisely the same time?
Can you describe the feature loss a bit more please?
Thanks a lot
Andrew
EDIT - Justin, I must have missed something previously, I just read your first post again - please ignore this post for now - appologies there mate.
Regards and Thanks
Andrew
Andrew 737
Quote from: Andrew 737 on May 19, 2014, 11:20:56 PM
Hello
Hi Justin
Thanks a lot
Andrew
What a fantastic sim - superb :)
Goodness knows how I missed the video, I must have had a 'blonde' (no offence to anyone guys, just a joke) moment!
Ok so I'm struggling to understand How you instruct each copy of GSX to run at precisely the same time?
Thanks Justin
Regards and Thanks
Andrew
dc8flightdeck
Hey now, Im blonde!  8)
All I did was to install a copy of GSX on each PC. Wideview takes care of the rest, no extra effort needed.
You loose GSX articulated movements on the client computers, like seeing the marshaller give hand signals. His hands do not move on the clients. When the marshaller walks his legs do not move, he just slides along the ground.
honestly, a lot of what you visually loose is not visible from the cockpit anyway, you have to place a monitor in an "outside" view to notice most of the missing animations. one would be the luggage moving from the vehicle into the cargo hold.
Andrew 737
#20
Hi Justin
I'll give this a go - thanks for the info bud, greatly appreciated.
Regards and Thanks
Andrew
dc8flightdeck
Now that I think about it, I do also have wide traffic installed. Im not sure if that has an effect on GSX or not. This is installed for FSX.
Andrew 737
I too have Wide Traffic Installed :)
Thanks for the tip though, this is the sort of thing that can drive one mad!
Regards and Thanks
Andrew
sstusek
this post is interesting, I am also using system with 4 pc's - 1 server, 3 wideview clients for scenery.
I was thinking how to use AES on wideview clients... without success!
First I thought I could control AES on multiple computers with AES Remote. This small program provides AES control from a client PC. It turned out that AES control is limited to send commands only to a single PC(IP)! Too bad, it would be very easy and straight forward solution if AES commands could be send to multiple computers. To do that AES control program should be modified...
Your question ..."how to get multiple copies of AES running at exactly the same time"... got me thinking again. How about mouse and keyboard sharing software like Hotkeynet, Input Director, Synergy or...
Some of the programs, so I've read, have sort of "mirror mode", which can mirror mouse and keyboard, just mouse, or just keyboard on networked computers.
That might do the trick to get multiple copies of AES running at exactly the same time?
I would have tried it myself but right now my system is not operational because I am upgrading some of my computers.
Simon
ckovoor
#24
I operate a WidevieW+WideTraffic-X based network of 11 pc's, in which the Server generates 2-D cockpit panels of various payware aircraft, 7 Client pc's generate the out-of-cockpit-window scenery views across a 182 deg-fov, 1 Client pc generates an external locked spot view, and 2 more Client pc's are used as Instructor Stations (running weather, EFB and flight-planning add-ons, and now, AESRemote).
I used AutoHotkey-L to open 8 instances of AESRemote (concurrently) at my remote pc (Instructor Station 2). Each was linked to one of my Client pc's generating scenery. Continuing with Autohotkey I applied appropriate key presses to activate the various AES functions across the Clients. The various ground activities including jetway extension/retraction, though not actively synchronised by WidevieW/WideTraffic, appeared to progress synchronously on the clients, because they were activated simultaneously (via the appropriate hotkey on the Instructor Station pc).
I can share the .ahk code and the method, if anyone is interested.
Chakko.
