need help creating a MCP for FSX.
Started by eisaacs, March 15, 2015, 09:06:43 AM
eisaacs
So I started this project a year ago. Trying to make it as closely as the real thing as possible. But I'm stuck. I have an arduino mega and I want to connect 5/ 5 digit 7 segment lcd display to work with fsx as the MCP. I have looked at link2fs and uploaded code to the board but I still cannot see an image.  can anyone give me the step by step any advice will help.
Hi Everton,
I have done some crazy things with the arduino, but 7-segment displays aren't one of them.  Thats going to be very tricky I am affraid as you will literally have to program each "SEGMENT" as an LED and then build your code to turn on the correct segments for each Number.
What would be Waaaaay easer is for you to integrate an LCD.  Then you can display the didgits on that.
rprather
Google "arduino bcd 7 segment" for some ideas.
This site shows a module that plugs into a PoKeys... probably very similar with Arduino.
http://www.flightsimparts.eu/Simulator_PoKeys_7Segment.html
jylhami
The Maxim 7219 chip is the way to go. You can control 8 digits with one chip, and the chips can be daisy chained. I guess 8 chips can be in the Daisy chain giving you a control over 64 digits with just 3 I/O lines.
http://playground.arduino.cc/Main/LedControl
https://www.pjrc.com/teensy/td_libs_LedControl.html Has pretty much all you need
I have done a King 165 radio with 4 of these chips. I did it with Teensy, but I guess it is pretty much the same, as they use the same processor. If you wan't to see the .ino file give me a PM and I can send it to you to get a jumpstart.
