Looking for a dimmer
Started by 727737Nut, April 13, 2015, 07:19:39 PM
Trying to find a 0-5V light dimmer that is high side pwm dimmer.  Everything im finding is low side ie PWM the ground side.
Jan737
Just curious, why a high side pwm dimmer?
This is a DYI solution, or are you looking for a ready one?
http://project.irone.org/power-width-modulator-with-555.html
Jan
All Real aircraft panels get the ground through the frame of the aircraft.  They also run on 5VAC so it is not a big deal. Butwhen you drive them with 5Vdc like we do then it becomes a big deal.  They are not isolated like LED lighting is.  Hence the reason for high side dimmer.
Thanks for the link but that is a low side dimmer.
If you want to make it high side, change the MOSFET in the circuit to a P-channel, and swap the location with the motor.
Ones that can deliver the kind of power you are looking for are pricy. That's why most everything it low side drive.
DUH! moment, Think back Rob! 60's 70's cars  lol  simple and works!
http://www.aircraftspruce.com/catalog/elpages/rheostat.php
