DC Motor Plus wiring help please?
Started by paulnd, May 03, 2015, 08:07:47 AM
paulnd
Hello,
I'll be very grateful if someone could help me wiring up my homemade TQ to an Opencockpits DC Motor Plus Card please?
My 3D printed throttle consists of 2 throttle levers each with a geared potentiometer and 6V DC motor with a clutch.
I've connected 5V between +V motor and GND and position 2 and 3 are set on the respective power jumpers. Motors are connected to MOT1 and MOT2.
Questions
Which analogue input should I use for the throttle pots if I want to use autopositioning? The manual is a bit confusing
QuoteAN5, AN6 and AN7 inputs can be used for the self-positioning of MOT-1, MOT-2 and MOT-3 motors
and then
Quoteentries AN1 to AN4 are connected to the sense of MOT-1, MOT-2, MOT-3 and MOT-4 motors respectively.
Should the motor sensor jumpers be closed for auto positioning?
I've used the test software and I'm able to move the motors in different directions by sending values to motor 1 etc but the analogue inputs make no sense and don't seem to correlate with the motor positioning, unfortunately the manual isn't very helpful.
I'm familiar with SIOC scripts but want to get the basic wiring correct before I get on with the script.
I'll be grateful for any assistance and hope that I've provided sufficient information.
Paul
paulnd
paulnd
thanks David, unfortunately it doesn't have much information on wiring the card. All I really need is a photo or diagram of a wired card for a TQ
Hi Paul -
The short answer is that you do not need to be concerned with any of that. The relationship of pot position and motor function can be more easily handled within the SIOC script.
See attachments.
paulnd
that's perfect, exactly what I was after
Thank you Fred
