October 19, 2026, 06:04:40 PM
317 Guests, 0 Users
  • Online today: 1,093
Guests: 317
Total: 317
Question for x-plane guru's
Started by 727737Nut, June 23, 2015, 03:55:53 PM
How in the world do you get reverse thrust to work in x-plane with a single pot per throttle.  It was easy in FSX and P3D.
I have a set-up that mimics the real throttle movement so from full forward to full reverse moves the Pot 300 deg.
Im pretty sure there's only a Toggle option in XPlane.
If you're using SimA or ProSim, it can be done within their software.
Nat's correct. Using X-Plane, my throttle quadrant has 2 micro-switches that are wired in series. When I run the throttles full reverse, both levers have to engage the switches for reverse thrust to engage.
