August 25, 2026, 03:53:06 PM
276 Guests, 0 Users
  • Online today: 1,130
Guests: 276
Total: 276
ISLOGO
What is Instructor Station ?
The Instructor Station is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
Instructor Station version 3.30 released
Started by luisgordo, September 18, 2015, 03:48:14 PM
luisgordo
Instructor Station version 3.30 has been released :
www.iStationGordo.com
MAJOR UPDATES --
  • Custom failures (10 user-defined failures can be specified in the "customfail.txt" file). Number of custom-defined failures will be increased in subsequent versions
  • Sequential start of networked PCs
  • Combination of conditions to trigger failures (speed and/or altitude and/or countdown timer)
  • Added map to drag-and-drop ACFT position in REPOSITION tab
  • Added map to follow ACFT position and display fixes, navaids, etc. in RECORDER tab
  • Added display of Approach plots to RECORDER tab
  • Saved Scenarios now include saving preset failures.  Training scenarios can be easily saved and loaded as required (engine out on take-off, etc.)
  • Now possible to set Season
  • Added Airbus/Boeing Project Magenta APU Fire failure
  • Added Airbus Project Magenta failures (AC BUS 1/2 Fault, Hot/Hung Start, High Oil Temp, Cabin Pressure Fault, IAS/Pitot Fail).
  • Added remote shutdown of PCs
Luis
Instructor Station
Flight Data Recorder Mobile
luisgordo
Instructor Station
