October 19, 2026, 12:59:13 AM
491 Guests, 0 Users
  • Online today: 490
Guests: 491
Total: 491
Real 737 RMI interface
Started by 727737Nut, October 19, 2015, 04:07:54 PM
Well I can call this project complete now. In the pic below you will see my RMI interface which I use to drive my real RMI's and also my compass card on my HSI.  Specs, Teensy 3.2, 6ea Pololu drv8825 stepper drivers set for 1/32 micro stepping. Servo city gears and hardware, ebay special 1.8deg 12-24v NEMA14 steppers.  Optical sensors for setting home/0 position at start up. 26vac 400hz synchros which output the angle signal used by the RMI  I have a few flights on it now and works great so i'm happy as a flying pig. :D
Awesome Rob!
I'm glad i didn't have to use synchros for mine, i'd have no hair left.  ::)
Interested in seeing how you coded this if you are willing to share
Quote from: mickc on October 19, 2015, 04:16:51 PM
Awesome Rob!
It was actually pretty easy, never opened the RMI up.  Key is getting the wire diagram to know which pin is which.   Code is below with one caveat, the stepper4 part of code is for my compass card. it is dead on with the sim except when passing the dreaded 359/0 degree line. It ones to turn a complete turn the opposite way to line back up with the heading instead going step per step across that line.
Quote//StepperTest
#include <AccelStepper.h>
const int homeButton = 0;
const int homeButton2 = 1;
const int homeButton3 = 2;
const int homeButton4 = 3;
byte hBval;
byte hB2val;
byte hB3val;
byte hB4val;
AccelStepper stepper(1, 21, 20);  //21=Step 20=Dir #31
AccelStepper stepper2(1, 19, 18); //19=Step 18=Dir #32
AccelStepper stepper3(1, 17, 16); //17=Step 16=Dir #33
AccelStepper stepper4(1, 15, 14); //15=Step 14=Dir #34
FlightSimFloat nav1;
FlightSimFloat nav2;
FlightSimFloat adf1;
FlightSimFloat magHdg;
float cur_pos;
float cur_pos2;
float cur_pos3;
float cur_pos4;
void setup() {
  stepper.setMaxSpeed(3000);
  stepper.setAcceleration(3000);
  stepper2.setMaxSpeed(3000);
  stepper2.setAcceleration(3000);
  stepper3.setMaxSpeed(3000);
  stepper3.setAcceleration(3000);
  stepper4.setMaxSpeed(2500);
  stepper4.setAcceleration(3000);
  nav1    = XPlaneRef("sim/cockpit2/radios/indicators/nav1_relative_bearing_deg");
  nav2    = XPlaneRef("sim/cockpit2/radios/indicators/nav2_relative_bearing_deg");
  adf1    = XPlaneRef("sim/cockpit2/radios/indicators/adf1_relative_bearing_deg");
  magHdg  = XPlaneRef("sim/cockpit2/gauges/indicators/heading_electric_deg_mag_pilot");
  pinMode(homeButton, INPUT_PULLUP);
  pinMode(homeButton2, INPUT_PULLUP);
  pinMode(homeButton3, INPUT_PULLUP);
  pinMode(homeButton4, INPUT_PULLUP);
  stepperHome(); //runs routine to home motors
void loop() {
  FlightSim.update();
  cur_pos = nav1 * 88.889;
  stepper.moveTo(cur_pos);
  stepper.run();  //ToPosition
  cur_pos2 = nav2 * 88.889;
  stepper2.moveTo(cur_pos2);
  stepper2.run();  //ToPosition
  cur_pos3 = adf1 * -88.889;
  stepper3.moveTo(cur_pos3);
  stepper3.run();  //ToPosition
  if (magHdg < 360) {
  cur_pos4 = magHdg * 88.889;
  else
  cur_pos4 = magHdg * -88.889; //- 360;
  stepper4.moveTo(cur_pos4);
  stepper4.run();  //ToPosition
void stepperHome() { //this routine should run the motor
  //stepper1.moveTo(300);
  //stepper1.run();
  delay(100);
  hBval = digitalRead(homeButton);
  while (hBval == LOW)
    //backwards slowly till it hits the switch and stops
    stepper.moveTo(33000);
    stepper.run();
  stepper.setCurrentPosition(0); //should set motor position to zero and go back to main routine
delay(50);
hB2val = digitalRead(homeButton2);
while (hB2val == LOW)
  stepper2.moveTo(33000);
  stepper2.run();
stepper2.setCurrentPosition(0); //should set motor position to zero and go back to main routine
delay(50);
hB3val = digitalRead(homeButton3);
while (hB3val == LOW)
  stepper3.moveTo(33000);
  stepper3.run();
stepper3.setCurrentPosition(0); //should set motor position to zero and go back to main routine
delay(50);
hB4val = digitalRead(homeButton4);
while (hB4val == LOW)
  stepper4.moveTo(33000);
  stepper4.run();
stepper4.setCurrentPosition(0); //should set motor position to zero and go back to main routine
matta757
Awesome Rob!
Mick,
How did you interface your gauges?
Matt
Quote from: matta757 on October 21, 2015, 11:23:05 AM
Mick,
Matt
Hi Matt.
My RMI is a genuine unit out of a -800 NG and does not use any Synchros like the earlier ones. It uses ARINC 429 decoders and 3 servo motor drives, one for each needle and one for the heading card.
I ditched the ARINC side of it, and converted the servo motor drives to micro stepper motor operation, and added home position sensors.
Running through SIOC and OC stepper drivers at the moment, but I am in the process of changing over to Arduino as the OC stepper boards aren't quite up to the job.
You can take a look here for more details https://www.facebook.com/media/set/?set=a.747866858655983.1073741838.727065570736112&type=3
Quote from: 727737Nut on October 19, 2015, 04:35:27 PM
Cheers Rob, thats great
My existing code in SIOC works fine for the wet compass and the heading card on the RMI, no issues with the 359/0 line.  Maybe you can try adapting the section in italics and see if it helps?
QuoteVar 0985, name CMP_HDG
  &CMP_STEPPER = &CMP_HDG * 100
Var 0990, name MAG_VAR
Var 0981, name FS_MAGVAR, Link FSUIPC_IN, Offset $02A0, Length 2
  L0 = &FS_MAGVAR * 0.005493164
  L0 = 360 - L0
  &MAG_VAR = L0
Var 0988, name FS_HDG, Link FSUIPC_IN, Offset $0580, Length 4
  L0 = &FS_HDG * 8.3819E-008
  L0 = ROUND L0
  IF L0 < 1
    L0 = L0 + 360
  L1 = L0 + &MAG_VAR
  IF L1 > 360
    L1 = L1 - 360
  &CMP_HDG = L1
Var 1001, name CMP_STEPPER, Link USB_STEPPER, Device 2, Output 1, PosL 3, PosC 0, PosR 7, Type H
QuoteMy existing code in SIOC works fine for the wet compass and the heading card on the RMI, no issues with the 359/0 line.  Maybe you can try adapting the section in italics and see if it helps?
As you will soon learn when going to arduino from sioc, SIOC did allot behind the scenes that with arduino we have to put in.  The code although both C do not interchange.  Below is the new perfectly working code thanks to a generous teacher in Brasil. No more 0-359 issues .
Quote#include <AccelStepper.h>
byte hBval;
byte hB2val;
byte hB3val;
byte hB4val;
float cur_pos;
float cur_pos2;
float cur_pos3;
float cur_pos4;
const long STEPS_PER_REVOLUTION = 32000;
const float STEPS_PER_DEGREE = ((float) STEPS_PER_REVOLUTION)/360.0;
void setup() {
  Serial.begin(38400);
void loop() {
  FlightSim.update();
  cur_pos = nav1 * STEPS_PER_DEGREE;
  cur_pos2 = nav2 * STEPS_PER_DEGREE;
  cur_pos3 = adf1 * -STEPS_PER_DEGREE;
  long currentPosition = stepper4.currentPosition();
  currentPosition = (currentPosition % STEPS_PER_REVOLUTION + STEPS_PER_REVOLUTION) % STEPS_PER_REVOLUTION; // positive modulo
  long targetPosition = (long) (magHdg * STEPS_PER_DEGREE);
  long cwSteps;
  long ccwSteps;
  if (targetPosition > currentPosition) {
    cwSteps = targetPosition - currentPosition;
    ccwSteps = currentPosition - targetPosition + STEPS_PER_REVOLUTION;
  } else {
    ccwSteps = currentPosition - targetPosition;
    cwSteps = targetPosition - currentPosition + STEPS_PER_REVOLUTION;
   if (cwSteps < ccwSteps) {
     stepper4.move(cwSteps);
  } else {
    stepper4.move(-ccwSteps);
  stepper4.run();
  delay(100);
    stepper.run();
  delay(50);
    stepper2.run();
  delay(50);
    stepper3.run();
  delay(50);
    stepper4.run();
matta757
Question regarding types of gauges... how does one know if a gauge is ARINC?
You need a schematic to be sure.  They can all look alike from the outside and have the exact same connector.  Usually, the the 737 classics and older with partial and full steam gauges are non ARINC. Allot of people confuse ARINC as there are several different ARINC standards.  429 is most common on newer stuff though.  My HSI and RMI use ARINC 561 for the DME, the rest of the pit is pure analog.
