Instructions Needed.
Started by idj4, November 15, 2015, 07:43:52 AM
idj4
Hi All.
Does anyone know where I can get the full instructions for the Opencockpits MIP components kit?  Nothing came with the kit & there doesn't seem to be any to download from their site. As you would expect with any kit I have a load of wires, pcb boards, terminal pins & open ended wires waiting to be soldered. Only trouble is, is I don't know what goes where. :huh:
Thank You.
Keep Well..  Ian
Does this help?
Using this you can see how the cards connect and their assignments
idj4
Quote from: wpslider on November 15, 2015, 10:39:25 AM
But you may be in the need of these:
http://www.opencockpits.com/uploads/manuales/Manual%20montaje%20MIP%20single%20trainer.pdf
http://www.opencockpits.com/uploads/manuales/Esquema%20conexiones%20-Wiring%20scheme%20MIP.pdf
Hi.
Thanks very much. I bought this kit.
http://www.opencockpits.com/catalog/mip-components-kit-p-456.html?cPath=86_43
which doesn't have the wiring instructions in the downloads tab. And the assembly manual link has an internal error.
And thank you too Warren. I will look at that too.
Keep Well..  Ian
Ian,
Email Sales and or Technical Support, I have found them to be very helpful in the past.
Les
wpslider
Quote from: idj4 on November 15, 2015, 11:11:09 AM
Hi.
In this case I suggest you to contact their support.
regards
