October 18, 2026, 02:45:12 PM
829 Guests, 0 Users
  • Online today: 984
Guests: 829
Total: 829
Wideview
Started by awdoman, November 15, 2015, 02:37:50 PM
awdoman
Hello all, I'm new to cockpitbuilders, and like many of us have been bitten by the bug to make my sim better, faster, and a stronger experience.  My issue is this I'm working on a 3 PC set up using Wideview .Only dealing with the 1st 2 at the moment to get the computers and views to align and work properly.   Specs: PC 1  Server   OS Win 7 pro 64 8gb 1866 ghz  Asus Crosshair V formula z w/AMD 8 core water cooled OC'd to a mild 4.62 ghz.  P3D v2.5. 1  24" ASUS monitor running 1920 X 1080 Center View.   1 20" ASUS monitor used for gauge panel (FreeFD).  PC 2  Client   OS Win 10 pro 64 8 gb 1600 ghz  Asus M5A97 LE R2.0 w/AMD 4 core water cooled  OC'd 4.55 ghz. P3D v2.5  1 ASUS monitor running 1920 X 1080 Left view at 22.5 degree angle.
My issue is this, after configuring both the server and client, all recommended settings on both server and client, aircraft saved to default startup on both, view configured for client, upon starting server PC,  then client PC, the Addon menu for wideview only shows on server for both client and server. And when I check to make sure both are activated, usually the Client is "inactive", so I activate, and then on server the plane slews up.  The "y" for slew is untouched.  If tried uninstalling both, restarting PC's, reconfiguring the .FXML for default "startup" on both PC's.   Anyone experienced this and how do I correct this behavior.
