October 18, 2026, 09:14:21 AM
607 Guests, 0 Users
  • Online today: 829
Guests: 607
Total: 607
Video of latest project
Started by 727737Nut, December 03, 2015, 07:21:15 PM
I retrofitted a Switek X25-168 gauge cluster stepper to inside of this real gauge. Using Teensy LC driving it directly from 4 output pins as you can see it stops on 0 perfectly each time. Was fairly easy to accomplish and super easy code. I highly recommend these steppers for any single needle gauge.  They make 315deg and 360deg versions for less than 2.00!
https://youtu.be/rBU14gAjDDw
That's just awesome!!!
Cheers, Rob.
Jan737
Looks great! I've ordered these steppers too.
Are you willing to share your code?
Jan
Quote from: Jan737 on December 04, 2015, 06:49:40 AM
Jan
No problem Jan and thanks Sam!  ;)
Quote//Secondary Engine Gauges
float map1 (float x, const float& x0, const float& x1, const float& y0, const float& y1)
  if (x <= x0) return y0;
  if (x >= x1) return y1;
  float gradient = (y1 - y0) / (x1 - x0);
  return y0 + (x - x0) * gradient;
#include <AccelStepper.h>
AccelStepper stepper1(4, 0, 1, 2, 3); //(Coils A1 A2 B1 B2
AccelStepper stepper2(4, 13, 14, 15, 16); //(Coils A1 A2 B1 B2
AccelStepper stepper3(4, 17, 18, 19, 20); //(Coils A1 A2 B1 B2
AccelStepper stepper4(4, 12, 11, 10, 9); //(Coils A1 A2 B1 B2
FlightSimFloat OilTemp1;
FlightSimFloat OilTemp2;
FlightSimFloat OilQty1;
FlightSimFloat OilQty2;
FlightSimFloat OilPres1;
FlightSimFloat OilPres2;
void setup() {
  pinMode(23, OUTPUT); //PWM out to #1 Eng Oil Quantity
  pinMode(22, OUTPUT); //PWM out to #2 Eng Oil Quantity
  stepper1.setMaxSpeed(100.0);
  stepper1.setAcceleration(100.0);
  stepper2.setMaxSpeed(100.0);
  stepper2.setAcceleration(100.0);
  stepper3.setMaxSpeed(100.0);
  stepper3.setAcceleration(100.0);
  stepper4.setMaxSpeed(100.0);
  stepper4.setAcceleration(100.0);
  stepperHome(); //runs routine to home motors
  OilTemp1  =  XPlaneRef("FJS/732/Eng/OilTemp1Needle");
  OilTemp2  =  XPlaneRef("FJS/732/Eng/OilTemp2Needle");
  OilQty1  =  XPlaneRef("FJS/732/Eng/OilQuantity1Needle");
  OilQty2   =  XPlaneRef("FJS/732/Eng/OilQuantity2Needle");
  OilPres1  =  XPlaneRef("FJS/732/Eng/OilPress1Needle");
  OilPres2  =  XPlaneRef("FJS/732/Eng/OilPress2Needle");
  delay(5000);
void stepperHome() { //this routine should run the motor to the internal stop
  stepper1.runToNewPosition(-450);
  stepper2.runToNewPosition(-450);
  stepper3.runToNewPosition(-450);
  stepper4.runToNewPosition(-450);
  stepper1.setCurrentPosition(0);
  stepper2.setCurrentPosition(0);
  stepper3.setCurrentPosition(0);
  stepper4.setCurrentPosition(0);
void loop() {
  FlightSim.update();
  float val = OilTemp1;
  val = map1(val, -50, 120, 0, 400);
  stepper1.moveTo(val);
  stepper1.run();
  float val2 = OilTemp2;
  val2 = map1(val2, 0, 120, 120, 410);
  stepper4.moveTo(val2);
  stepper4.run();
  float L2 = map1(OilPres1, 0, 60, 0, 385);
  stepper2.moveTo(L2);
  stepper2.run();
  float L3 = map1(OilPres2, 0, 60, 0, 385);
  stepper3.moveTo(L3);
  stepper3.run();
  float LO = map1(OilQty1, 0, 5, 22, 255);
  analogWrite(23, LO);
  float L1 = map1(OilQty2, 0, 5, 26, 255);
  analogWrite(22, L1);
Caflyt
You're a genius Rob.
Great job!!
Craig
Jan737
Thanks for the code. That helped a lot.
Jan
Quote from: Jan737 on December 05, 2015, 07:13:24 AM
Jan
Glad it did but remember I am using Teensy and X-Plane so coding is a little different.
