October 14, 2026, 03:45:02 PM
297 Guests, 0 Users
  • Online today: 1,081
Guests: 297
Total: 297
FDS shell and Simworld hardware
Started by Sam Llorca, December 19, 2015, 12:55:20 PM
Sorry guys but I had to start a new subject with the same tittle because I can't re-open the last one.
Just to give you a final report on the Simworld MCP fit on my glare shield.
It fit, but you can't use the Simworld bracket they provide, with the MCP support bracket the MCP is 1/2 inch wider than the regular G3 FDS MCP.
But using the FDS MCP support bracket and a bit of Fabrication you can make it happen, here is the finished product...
Cheers!
Ridgenj
Thanks Sam, you answered my question.
Luis
Moderator!
Now I can open both treads,  you may want to delete the latest one and transfer the pictures over to this one, I wasn't able to open the oldest one yesterday.
I'm glad I could help Luis.
It looks fantastic!
Ridgenj
Looking forward to see your first impression, your contributions are always appreciated Sam.
Cheers from sunny Miami
Luis
Thank you Luis, see I'm a hands  on guy, I like building stuff, metal cutting, welding, I'm a car guy, my first hobby was rebuilding old cars, I love that stuff, when I get into trouble is with computers and assigning stuff, I've got much better in the pass 3 years tho.
Sunny Miami! Hasn't been too sunny lately!
Cheers!
Hello Guys,
Just getting back to you on the Simworld MCP installation.
Is just awesome the way it looks and feel, you can actually hear and feel every click, soft lights with a dimmer on the MIP, I did one test flight and all I can say is, !It works!
Took a little while to get here but it made it before the New Year!
Merry Christmas to all of you and a Happy New Year!
Cheers!
The latest pictures on the new Simworld MCP install!!!
Tis' a beautiful thing.....!
I know they look much better in the flesh, its just so hard to get photos that do it justice when its dark.
I know,  my phone is not the best to take pictures.
Looking good Sam.
Do you still have the parts from the FDS one? I'd be curious in diagnosing what when wrong with it.
Hi Kyle,
Yes I do have the parts from the old one, the encoders and wiring looks good to me, if there is an problem it has to be with the boards,  all I know is that Prosim is not detecting any switch contact or spikes like before.
Anyone willing to investigate?
Quote from: Sam Llorca on December 22, 2015, 04:44:22 AM
Hi Kyle,
Are you saying Sam, that when you removed the FDS MCP/EFIS outside of the cockpit it works just fine?
Hi Kyle,
Ya I'm curious if the encoders themselves were wearing out, or the short we found fried part of the board.
I'd be happy to have a look at it.
@Trevor
When the FDS MCP started malfunctioning,  I checked on ProSim737 switches tab and there was one or two switches spiking or sending contact signals into the prosim system .
After removing the old MCP and installing the new one, all switches contact spikes went away, they are not there anymore.
My understanding of it is that there was a issue with the electronics inside the MCP, I didn't see any loose wire or anything  else.
@Kyle
The short was on the negative wire, don't see why it would short out,  the whole cockpit is negative wired.
  :huh:
Quote from: Sam Llorca on December 22, 2015, 07:10:53 AM
...The short was on the negative wire, don't see why it would short out,  the whole cockpit is negative wired.
  :huh:
It's strange to consider but it can happen.
It depends on how the board was designed to be used. If it was an isolated design (which most powered by a plugin transformer like that are) a ground loop can occur causing several possible issues, including the power supply going out of regulation and providing too high a voltage.
I've damaged several power supplies by inadvertently connecting the isolated negative side to earth ground or primary side ground during design testing.
That makes sense..  Ok, I just misunderstood your post.  I figured that once the new mcp was in all your problems would go away!  Great News..  (How does it feel?)
