B737: audio connections
Started by MjTom, January 26, 2016, 01:58:30 AM
MjTom
Hallo,
I need some information (as always).
In a B738NG cockpit are the following audio connections:
1x 6,3mm jack in sidewall left and right (Pos. 1)
1x XLR 5 pin in side window unter the chartholder left and right (Pos. 2)
2x 6,3mm jack eyebrow window
optional 1X XLR 5 pin and 1x 6,3mm jack
confirm or did I forgot something?
so long, Thomas
Hi Tomas,
A few corrections:
The Jacks in the sidewalls are for Hand Mics, and are not 6.3mm, they are smaller - 5.25mm
Also in the eyebrow window liner, there is 1x 6.35mm jack for the headphones and 1x 5.25mm javk for the boom mic on each side.
The XLR 5 pin you show in Pos 1 is not an audio connection, it is the power and sense connection for the window heat in the opening side windows.
The XLR in the eyebrow liner is an option fitted by some airlines which replace the 2 separate Headphone/Boom mic connection with one XLR plug.  This can also be done with adaptor cables.
MjTom
Quote from: mickc on January 26, 2016, 02:49:15 AM
Hi Tomas,
A few corrections:
........ expressed very nice !
I suspect, that my version would be too easy!
I should have stayed with my lego building blocks.....B737 HC = barrel without ground
some other question:
"connection for the window heat in the opening side windows"
Where does the spiral cable?
Is it only connected, when window is open or always?
thanks and so long, Thomas
737man
Does anyone have a resource for the volume and controls black bar in the photos for the mics?
Not sure, but if you refer to my pics, it is a real aviation  intercom which you can find en EBay for $50 ±
[ebay]172077888999[/ebay]
[ebay]161958702257[/ebay]
[ebay]141877723787[/ebay]
MjTom
Hallo,
Can you confirm that this are the electrical connections for the window heater?
sorry, for my many questions....I have no chance to visit a real cockpit.
everything I do not find in the www., I am in need of help.
so long, Thomas
Quote from: MjTom on January 27, 2016, 12:54:47 PM
Quote from: MjTom on January 26, 2016, 03:39:03 AM
Correct, this is for the side window heat, and is connected at all times.
