October 18, 2026, 01:59:22 PM
408 Guests, 0 Users
  • Online today: 984
Guests: 408
Total: 408
737-300 Motors and slip-clutch Just confirm before buy.
Started by kurt-olsson, March 29, 2016, 04:03:08 AM
Time to order some motors and clutches for my throttle.
This will be my next big thing on this item and it will take alot of time before i mount a setup that will work.
But i think i have made up my mind on my parts for the motors and clutch.
What do you think of this?
Motors: 2x
http://www.electrokit.com/en/dcmotor-with-gearbox-612vdc-200-1-15rpm.51559
Think they have the right speed (max speed, will be modified in the software later) and torque and drives from 12V with 6mm shaft.
Slip Clutch: 2x
http://www.conrad.com/ce/en/product/184121/Mentor-716-Safety-Slip-Coupling
Have configurable tension to it and will fit the 6mm shaft.
If you want it to feel realistic, I would go with a stronger clutch.  Those are quite weak compared to the feel of the real thing.
I used Huco 6 plate clutches, and after calibration, they have the same resistance as the real throttle.  They will last a lot longer too.
These do have 8mm bores, but 6mm  to 8mm adaptors are easy to find.
Motors should be fine.  Have you thought about interfacing and motor drivers?
i was also a little sceptic about the slip-clutch. I think this peace is really important to get the reel "feel" as you say. needs to be strong and easy to calibrate. But they are really cheap, so i might order a pair so i can start testing.
I will search around for some alternatives. The motors i think i will order today with some mounting brackets.
Driving the Motors will be the easiest part. I will be using a Teensy with an H-Bridge and then use normal PWM in combination with string pot sensors. I will write the code myself. I will be mapping it with some X-plane ref for "A/T" set position values.
I will also check if the movement on the string pot is higher > MAX_AT_SPEED. If so, i will disconnect the A/T as if someone manually yanked the throttles.
If i knew the conversion would be this much fun i would have ordered it years ago!
With the info i have now, i will probably also go for real OEM yokes and give control-loading a try also with sprockets and chains! =)
Also need to go to my local store to get some wires and sprockets for the throttles. =)
By the way, have you felt the real throttles? Maybe if i get the same clutch as you, you can give me the info on how much tension you have on your clutch? that way i would be sure that i have the right settings.  Do you have a link to those clutches?
