October 20, 2026, 02:24:43 PM
329 Guests, 0 Users
  • Online today: 797
Guests: 329
Total: 329
B737 Rudder adjusting crank unit help
Started by 737man, March 29, 2016, 04:55:35 PM
737man
Does anyone know the range of motion that the crack will turn?  Mine looks like it only does 270' is that correct?
It should turn 360 degrees, as it is connected to a long screw thread, so multiple turns are required.
Is the pin retracting all the way when you pull the knob out?
737man
I will check it tonight....it is off of a retired 737.  It has pins in the back that restrict the movement.  I will send pics later...cheers
