MCP XPlane issue
Started by Bob Reed, June 16, 2016, 05:50:55 PM
Is there anyone out there using the MCP with XPlane? I had this all setup and working fine. Took it apart to get it out of the way to build the shell and now.... Put everything back together and I have an MCP issue and it is in the Auto Throttle. If I engage the AT my thrust levers no longer work. And now once engaged I can not disengage the AT. This happens on 2 different computers so 2 separate MCP setups. Before I took it apart this setup as it is, worked perfectly..... Any ideas?
I have found the issue and fixed it. Issue is when PM sets the AT it also sets the AT in XPlane. So the fix is, when you push the button to disconnect the AT you have to program the button to disconnect PM and Xplane's AT....
Ok so I thought I had fixed this but I have not. So I am still open to ideas.
