October 16, 2026, 03:16:42 AM
700 Guests, 1 User
  • Online today: 849
Guests: 700
Total: 701
Complex Knobs
Started by AtomicSheep, June 29, 2016, 06:36:15 AM
AtomicSheep
Hi Guys,
I'm trying to figure out how to make complex knobs such as the ones seen on the 737 EFIS.
http://www.virtualavionics.com.br/va/114/bundle-mcp737-r-efis737-pro.jpg
Does anyone have any tips on how to make them? Namely... theres the RADIO/MINS/BARO rotary knob and the IN/BARO/HPA knobs which have two levels of rotating selectors. More still, there's buttons "RST" and "STD" on these knobs.
mikeybear
I think these are pretty close to what you're after
http://www.leobodnar.com/shop/index.php?main_page=product_info&cPath=98_75&products_id=197
I think I still have a set at home if you want to see the individual parts
Dave
AtomicSheep
I'm not after 737 parts, I'm building a different plane, just trying to figure out how to make similar knobs.
mikeybear
These aren't 737 knobs, they are an off the shelf item for dual encoders
I'll post some pictures of how they work over the weekend .
but basically they  rely on a collet , the largest is tightened with a nut, the smallest with a screw on the end.
( pictures will make  more sense )
Dave
mikeybear
Here are the pics,
I also bought some cheap knobs off ebay  (about £3 for 10 ) that use a similar mechanism
I think they  were also available in 4mm , but it was quite a while ago.
This might be a  cheap source of the collets if you wish to make your own knobs.
Dave
http://www.ebay.co.uk/itm/10-x-Gray-Ribbed-Grip-4mm-Split-Shaft-Potentiometer-Control-Knobs-Caps-/290915121433?hash=item43bbe47919
http://www.ebay.co.uk/itm/10-x-Gray-Ribbed-Grip-6mm-Split-Shaft-Potentiometer-Control-Knobs-Caps-/290914805342?hash=item43bbdfa65e
AtomicSheep
Quote from: mikeybear on July 01, 2016, 05:34:54 AM
Dave
Thanks Dave, I didn't even know a dual concentric encoder existed! I thought I needed to drill a hole through one rotary encoder and shove another one through the first one.
I'm not sure how the collet  mechanism works but I'm sure it's simple and I'll figure it out. Great advice on getting those parts you suggested for the collets.
mikeybear
The dual shaft encoders are on the Leo Bodnar site as well , I bought one, but have never used it,
what I have done instead , and this might offend the purists :) , is to use a single encoder , with a push switch build in so you turn the knob for one setting, and push and turn for the other.
Dave
