Lighting breaker panels
Started by jackpilot, June 29, 2016, 12:19:24 PM
Added two Wemac swivel lights for the back wall , lighting up the breaker panels.
High load 24v  bulbs were replaced by 12v led equivalents which emit no heat and no heavy wiring.
I am getting ready to build the back walls to my sim and mount breaker panels. I see that you have a metal frame on each side of the panels. Is that an approximation of what is in the real aircraft or done for your convenience?
I was thinking of just mounting them flat to the vertical panel. I am lucky in that I have a real set of breaker panels and will be using the hinge mechanism to add a further level of realism.
Jim
