PC Specs and external view suggestions
Started by amorealex, September 21, 2016, 09:43:20 PM
amorealex
Hello all,
I have already placed my order for a Simworld SST and I'm waiting for the time to pass.
I will use P3D and built the following PC:
  • i7 6700K (I will OC to 4.5-4.6 GHz)
  • GTX 1070
  • 16 GB RAM
  • 2 SSDs (1 for Win10 and 1 for P3D and add-ons
  • 650W PSU
I haven't decided yet about the external view.
I'm between 3 24" monitors or 1 55". Any suggestions which way to go?
Also, I have to build one more PC for Prosim and some add-ons like ActiveSky etc.
Should I go for i7 too like the main PC or not?
Alex
Usually avionics PCs do not require Steroid status, but overpower is always better than under.
Just allow for a graphic card with at least 4 outputs for the various MIP screens (monitors)
Go wild for the outside view, a large TV or a projector , much better (IMHO) than tiny 3 views with low FPS.
amorealex
Just received my Simworld SST with Single CDU bay and lower EICAS.  :D
The whole unit has 5 VGA inputs:
1 for Chrono
1 for PFD/ND
1 for upper EICAS
1 for lower EICAS
1 for CDU
My plan is to drive the whole unit with 1 PC as I have another powerful one for my P3D installation.
Is it better to build a small PC with 3 video cards with 2 outputs each or just 1 video card and go for VGA to USB adapters?
Alex
Nice Alex
Just be warned. Your starting with a single seat... the dual seat won't be far behind lol. Always plan for the future :)
amorealex
I know Trevor. :)
But I don't have enough room for a full cockpit.
As soon as I move to a bigger house, I sure go all the way for the real deal!
Alex
I use 3 PC's in my setup.  1 does the MIP Displays ( 2 on video card and 1 USB to vga ) I notice a studders on my USB to vga sometimes.
My other PC does CDU and MCP. On a dual head Video card.
Not that what I do is right. But if I had to have more monitors I would use Usb to vga because they are getting better technologically and preform as well as required.  And they are cheaper than a multi head video card which can be less than ideal.
Quote from: Trevor Hale on January 10, 2017, 05:26:58 AM
Nice Alex
...nature always finds a way. :-)
For your set up I would recommend two CPUs, the internal cockpit displays could all be run from a single Radeon W600 card. Use the other PC as your host for all your other stuff and out the window displays.
