October 19, 2026, 07:27:29 AM
495 Guests, 0 Users
  • Online today: 1,033
Guests: 495
Total: 495
USB hub or direct
Started by iwik, November 19, 2016, 09:58:43 AM
I am building a new system and current mother boards seem to have 8 ports. So was wondering if it would be better to run my remaining usb devices directly from the pc ports or add another hub. Currently
using a 7 port hub for my 20 odd gauges. I know it has the drawback
of more cables but are what the pc does is just like another ext hub.
Hub i use are industrial types with many TT's built in.
Comments appreciate.
Les
Guys,
I will put the question this way round. How many of you are using all your usb ports to drive things and then adding hubs if necessary .
Les
I prefer to go straight off the motherboards USB but have found that if your cable gets to long issues present themselves.  I use a powered hub when the run is too long (more than 15ft for me).
I add industrial powered hubs when necessary. (Typically ones with dedicated transaction handlers per port. ) never had any issues using this approach.  When I discovered how easy it was to add microcontrollers to interface with xplane, I run out of USB ports at an alarming rate.
Thanks Guys,
Will buy another USBfirewire . I have still to connect Yoke,Pedals,GPS
and im sure some more will pop up.
Les
