June 17, 2026, 12:29:25 AM
96 Guests, 0 Users
  • Total Topics: 7,901
  • Online today: 152
  • Online ever: 13,689
  • (May 23, 2026, 05:33:42 PM)
Guests: 96
Total: 96
ISLOGO
What is Instructor Station ?
The Instructor Station is meant to assist Aviation Professionals, Flight Simulation Enthusiasts and Home Cockpit Builders using Microsoft® Flight Simulator (FS) 2004™, FSX™ and ESP™, Lockheed Martin Prepar3D® and X-Plane®.
The Instructor Station allows setting the aircraft on an approach to a runway of choice under any weather conditions, start-up and shutdown network computers (fully customizable), program or set aircraft system failures at any moment, calculate the amount of fuel required for a flight and load it to the aircraft, record flight performance (approaches, manoeuvres, landings, take-offs, etc.) and plot it graphically, and many other things!
Setting OAT through Environment (Advanced)
Started by Trevor Hale, December 13, 2016, 02:43:26 AM
Hi Luis,
When setting OAT through the advanced window in Environment, the temperature changes right away, but after a second or 2 it sets itself back to the temperature displayed in the left window at the Aircraft.  No other active weather sources are running, and Prepar3d V3 Shows (User Defined weather) Because it is being set from Istation.
Am I missing something?
luisgordo
Hi Trev,
This should work properly - are you using the latest version (3.46)?
Let me know.
Luis
Instructor Station
www.iStationGordo.com
Flight Data Recorder Mobile
Yes when I installed it I went to get the updates and noticed 3.46 was there.
I will try some more testing and let you know how I make out. Could be an issue on my end somewhere.
I will let you know after tonight if the problem still persists.
