What type of switch is cross-feed on boeing 737-800
Started by airupthere, January 28, 2017, 07:34:50 AM
airupthere
I'm building an 800 model. I have a 8-position rotary switch right now that I was going to use for the cross feed on the OVH fuel panel. But it just occurred to me, maybe that's not the right type to use? Should it be a rotary encoder instead?  Any thoughts or input is welcome.
Rotary indexed 90°.
Hard to find
If you are not too fussy about it a 45° will do the job (8 positions)
airupthere
Thanks a lot guys!! I like that switch you recommended Dave.. My uncle is 737-800 typed, and he said there's no clicking.. so I think I would skip the 45 8-position. the 90 degree, 4 position seems like it would be perfect.
You will have clicks with both. 2 cliks between the 90° extremes.
Dave's switch should be good.
Also 90° no clicks
[ebay]302118024480[/ebay]
[ebay]252391162589[/ebay]
All good options!
Just for reference, this is what the real one looks like, i listed one for sale here a while back
http://www.cockpitbuilders.com/community/index.php?topic=4975.msg36327#msg36327
mikeybear
Quote from: airupthere on January 29, 2017, 07:53:35 AM
Not sure if its relevant, but the "clicks" come from a spring and ball bearing which can be removed iirc
Dave
