October 18, 2026, 09:38:40 PM
466 Guests, 1 User
  • Online today: 1,142
Guests: 466
Total: 467
Congratulations.. It's sort of a Beech Throttle Quadrant...
Started by RayS, February 02, 2017, 10:17:47 AM
The 1900D Throttle replacement project is under way. Plan is to use a Teensy Microcontroller for all the joystick axis and Aileron/Rudder/Elevator trim. The Carenado 1900 has a bug in that using reverse thrust only zeros out the prop blades and reduces the throttle to 0. What should happen is the prop blades to to full reverse and the engines spool back up to X%.
Interestingly, the bug doesn't manifest when you use a 2d cockpit view. It only is an issue with external hardware.
The quadrant looks great. I have built a 1900 with the same software, now I need to go look at the reverse behavior to see if I am experiencing it also.
