October 17, 2026, 10:38:07 PM
677 Guests, 0 Users
  • Online today: 1,265
Guests: 677
Total: 677
CP Flight WXR Panel / Cargo Fire panel questions
Started by AngeloC, March 02, 2017, 07:35:44 AM
AngeloC
Hey guys, running FSX-SE, Project Magenta and have the CP Flight MCP Pro with WXR and Fire Panel connected. For some odd reason the Cargo Fire Aft Arm button sends pause (P) command to the sim.
Prior this on the WXR panel there was a small white square button that was assignable to any function you would want and I am fairly sure that is where pause used to be. I would like to make an assignment there for a key board press.
I contacted CP Flight for assistance and they said they don't know and seek PM for help. Tried PM but no reply so far, can anyone help me out? Ive looked and looked and cant find anything on how to set any instructions on the CP equipment.
I don't own any cp flight equipment but if its sending a keystroke directly to FSX then wouldn't it be possible to just change the key assignments directly from within the controls/button key presses page or via Fsuipc?
In the PM manual there should be a list of keystrokes/offsets also. As I have never used cp flight equipment Im just guessing here.
AngeloC
FSUIPC doesnt see it as a button though. I can press anything on the CP Flight gear and its not being seen by FSUIPC or yes I would of done that. I am not sure how this even got set as so, no clue where to look to change it either...
Scratching my head.
Please post your mcp.ini text file and I will look at...
Also, read and check this:
http://www.cpflight.com/sito/dettagli/pm.asp
Did you by chance recently update your PM programs or any Windows updates? If so, that could be where the changes started. Therefore, either rollback your files or you hunt the problem down.
For the hunt, I looked at my MCP.ini text file and there are some entries you need too look at on yours:
                              / For CPFlight 737 MCP hardware www.cpflight.com
ForceHardwareLight=Off
UseInstLight=Off
IgnoreBattery=Off
                              / Ignores pmSystems battery and FS
                              / Avionics (Battery)
IgnoreAvionics=Off
                              / Ignores only FS Avionics (Battery)
DisableFSMessage=Off
                              / Disables sending messages to FS
                              / Window
NoMenu=Off
                              / Removes Menu access and close button
PauseMetric=Off
                              / First Officer Meters Pushbutton
                              / sets Pause
????????????????CargoReset=Off
                              / Cargo Buttons used for FS reset
                              / via Instructor Station (CP Center
                              / Console only)
CargoPause=On
                              / Cargo Button used for FS Pause
                              / (CP Center Console only)
CPFlightIO=On
                              / Set CPFlightIO=Off to *disable*
                              / digital and analog input/output
CPFlightComm= 4????????????????
My questions:
1. In between my finger pointers, you will see the CargoPause= ...is yours On or Off?
2. Does your CPFlight MCP work normally right now?
3. What is your number for CPFlightComm= ...port number?
4. Your FSUIPC interface screen is not going too see these buttons, but FSUIPC is there in a different way, did you checkout the link I posted in the previous reply?
5. The small white button on the WXR panel that was assignable before, how did you assign it in the past...what method?
That is about as much as I can say, without seeing your files. The main thing is, if everything was working and it changed, we need too find out what cause the change along with fixing it; otherwise, this will happen again and could be much worse.
AngeloC
Quote from: blueskydriver on March 02, 2017, 09:54:20 AM
Here is the .ini and I see what you are saying now.
[Project Magenta MCP]
Build#515
[Display]
Title=On
Menu=Off
WindowName=MCP (Active) Press Ctrl-L for Logger, Esc For Menu
Topmost=Off
FSWindow=Off
Minimized=Off
                              / Starts up minimized
NoMinimize=Off
                              / Doesn't minimize MCP on double-click
[User]
Log=On
SerialLog=Off
                              / To log the serial communication
CycleMilliSeconds= 50
                              / Speed of the MCP cycle, ideally
                              / set to 50-70 ms
Top= 0
Left= 0
                              / Top/Left coordinates of the MCP
                              / program
Width737= 2400
Height737= 570
Width747= 15360
Height747= 3345
Width777= 11925
Height777= 2460
                              / Heigth and width of MCP for the
                              / various types
MCPType=737
Intervent737=On
                              / Enables SPD intervention buttons
                              / for the 737
ClassicEFISSel=Off
                              / When set to On, ND modes are selected
                              / with the old method, when set to
                              / Off, 8 modes are selectable...
                              / APP/VOR/MAP/PLN ARC and CTR
DelayMouseClick=On
                              / if mouse reaction is too fast,
                              / you can delay it setting this flag
                              / to On
Font=mcpfont
FontFactor= 1.27
[VNAV]
DescentSpeedControl=On
                              / when set to off, pilot controls
                              / speed with the throttle
[Aircraft]
[PROJECT MAGENTA 737-800 PAINT1 (DEFAULT)]
[D:\STEAM\STEAMAPPS\COMMON\FSX\SIMOBJECTS\AIRPLANES\PROJECT MAGENTA 738\PMX737-800.AIR]
MinIAS= 100
                              / Minimum selectable airspeed
DefaultIAS= 100
DefaultAltitude= 10000
                              / Default Speed and Altitude select
                              / on startup
AutoHDG=On
AutoVS=Off
                              / Will automatically select the current
                              / HDG and V/S when mode is engaged
MachAltitude= 0
                              / Will automatically switch to MACH/IAS
                              / when this altitude is crossed (e.g.
                              / 23450), 0 disables
AutoCRS=Off
                              / When set to ON, VOR/LOC will *not*
                              / go into intercept ARM mode first
AllowStabTrimOverride=Off
StabTrimDeflect= 6000
                              / Disconnects A/P when Elevator or
                              / Aileron is moved more than the
                              / deflection value (default 6000)
                              / This option needs to be enabled
                              / via bit13 offset 0x50A - monitor
                              / bit13 0x5528 for current setting
StabTrimOverrideActive=Off
                              / This sets the option above to always
                              / be active
Rollout=On
                              / MCP will steer the aircraft during
                              / the rollout phase after an autoland
DisableAdd20Kts=Off
                              / Will not add 20 Kts to speed during
                              / TOGA if set to On
AllowAPOnGround=Off
                              / Allows engaging AP on the ground
NoModeAfterTOGA=Off
                              / Doesn't automatically enable FLCH
                              / after TOGA mode
UsePanel=On
                              / Set to On if the FS panel or remote
                              / programs are used for MCP interaction
PushButton=Off
                              / Enables the use of the pushbutton
                              / for SPD, ALT and HDG
SpeedProtect=Off
                              / Enables speed protection for A/P
                              / modes
SELCurrentSpeed=On
                              / MCP will take the current speed
                              / when any speed mode is engaged
                              / for the first time
TerrAlt=Off
                              / Alternate Terrain Mode
Flare= 20
                              / Altitude above ground at which
                              / the flare is initiated during autoland
N1ref= 95
N1TOref= 98.6
N1GAref= 95.1
N1CLBref= 91.2
N1CRZref= 93
ThrRedAlt= 1000
                              / Defaults used for reference thrust
                              / and thrust reduction altitudes,
                              / only if no CDU detected
MaxROC= 6000
MaxROD= 6000
                              / Maximum rate of climb/descent
ClimbThrustLimiter=On
                              / Limits the climb thrust increase
                              / if the speed increases too much
                              / during FLCH/LVLCHNG climbs
Climb2000Spd=Off
                              / Climbs with SPD mode during FLCH/LVLCHNG
                              / of less than 2400 ft
FlightIdle= 10
ApproachIdle= 15
                              / Min Idle Value for Flight/Approach
                              / (default 10% and 15%)
UsePMAutobrakes=On
                              / Enables the PM Auto Brake, do not
                              / use the FS autobrake system at
                              / the same time
DisableAutobrakes=On
                              / Switches Off Autobrakes below 30
                              / Knots, both for PM and FS AutoBrake
                              / System
DisableBrakes=On
                              / Disables the writing of any brake
                              / valuesof the MCP for Rollout -
                              / this is *not* the Aurobrake System,
                              / if you use PM autobrake, then this
                              / has to be off
BrakeFactor= 0
                              / Brake factor in percent, default
                              / 100%
BrkDiscPark=On
                              / Brakes disconnect Parking Brake
ParkNeedsBrk=Off
                              / Parking Brake Needs Brakes to be
                              / Pressed to engage
UsepmNavSounds=Off
                              / Will not write Nav Sound flags
                              / to FS Offsets but to Project Magenta
                              / Offsets
StbySets1200=Off
                              / Will set transponder to 1200 when
                              / standby is selected
SwapCRS=Off
                              / Swaps CRS 1 and CRS 2
[Input]
MouseWheel=On
MouseWheelInvert=On
                              / Allows you to 'turn the knobs'
                              / of the MCP using the mouse wheel,
                              / you can also invert the direction
FSBusWriteBack=Off
                              / Will write back Speed and V/S values
                              / to offsets 0x5406 and 0x540C respectively
[Autopilot]
APProjectMagenta=Off
                              / Enables the PM autopilot and overrides
                              / the FS autopilot
APBankFactor= 70
APPitchFactor= 20
                              / Autopilot pitch and bank factors,
                              / the higher the value, the larger
                              / the corrections
DynamicPitch=On
                              / the FS autopilot
DynamicUseLoHi=On
DynamicPitchLow= 20
DynamicPitchHigh= 11
                              / Dynamic pitch will use low (close
                              / to 100kts) and high (close to 350
                              / kts) values
DynamicPitchTAS=Off
                              / Currently Disabled
                              / Project Magenta Autopilot for Pitch
                              / and Bank modes
[Hardware Connections]
                              / Enter Comm port the device is connected
                              / to, please do not use this if you
                              / do not have any hardware connected
                              / e.g. enter = 2 for COM2:
                              / Precision Flight Controls MCP hardware
                              / www.flypfc.com
PFCComm= 0
PFC9600=Off
                              / Important, the PFC9600 flag should
                              / be set to OFF for normal use, currently
                              / it is just for testing purposes
CautionThroughPass=Off
                              / PFC Caution Button pressed are
                              / not handled, but passed through
                              / to 0x5534
UseInstLight=Off
IgnoreBattery=Off
IgnoreAvionics=Off
                              / Window
NoMenu=Off
PauseMetric=Off
                              / sets Pause
CargoReset=Off
                              / Console only)
CargoPause=On
CPFlightIO=On
CPFlightComm= 8
DisableMIP=Off
                              / Set DisableMIP *disable* CPFlight
                              / MIP handling (e.g 737 sixpack troubleshooting)
                              / For FDS G1 Hardware Communication
FDS_G1_Comm= 0
                              / Flight Deck Solutions FDS Glare
                              / On/Off
FDSGlare=Off
                              / For Daken IFS Hardware
DakenSkys_IFS_Comm= 0
                              / FSC MIP Hardware
FSCMIPComm= 0
FSCMIPInvertGear=Off
      /Inverts Gear Direction
FSCMIPInvertSixPack=Off
      /Inverts both Sixpack Anunciation Lines
                              / FSC Throttle Hardware Comm
                              / http://www.flightsimulatorcenter.com
FSCThrottleQuadrantComm= 9
FSCNOTMotorized=Off
FSCTQMotorDisable=Off
      /Disables the motorization of the throttle
FSCTQTrimMotorDisable=Off
      /Disables the motorization of the trim
FSCTQTrimSpeed= 30
      /Sets trim motor speed 0 min 255 max (default 30)
FSCTQInvertTrim=Off
      /Inverts Trim Motor Direction
FSCTQInvertTrimWheel=Off
      /Inverts Trim Wheel Direction (when stab trim disconnected
FSCTQTrimOffset0= 60
FSCTQTrimOffset10= 142
      /Offsets Trim Indicator for Trim 0 and Trim 10
FSCTQInvertSpoiler=On
      /Inverts Spoiler Potentiometer Direction
FSCTQInvertSpoilerMotor=Off
      /Inverts Spoiler Motor Direction
FSCTQCalib= 0
      /UnCalibrated=0 - Calibrated=1 - Mixed=2 - Diff=3 - 2SameAs1=4 - useAdjust=5
FSCTQAdjust= 0
      /Adjusts Throttle 2 position by X
FSCSplArmPos= 208
      /Sets Spoiler Arm Position
FSCRevPct= 35
      /Travel of reversers before they are activated, min 15%, default 35%
FSCThrottle1Min= 54
FSCThrottle1Mid= 128
FSCThrottle1Max= 243
FSCThrottle2Min= 54
FSCThrottle2Mid= 128
FSCThrottle2Max= 241
FSCReverser1Min= 0
FSCReverser1Max= 151
FSCReverser2Min= 0
FSCReverser2Max= 122
FSCSpoilerMax= 249
FSCSpoilerMin= 0
FSCSingleThrottle= 0
FSCSingleReverser= 0
FSCThrIntervent=Off
                              / FSC Throttle Hardware Ver 3
                              / Cockpitsonic EHID
                              / http://www.cockpitsonic.com
EHIDComm=Off
                              / Can be set to 'On', 'Off', 'localhost'
                              / or IP Address
                              / ELAN MCP hardware
ElanComm= 0
ElanBaudRate=
                              / Please leave ElanBaudrate empty
                              / unless you know what you are doing(!)
                              / Aerosoft 747 MCP hardware www.mcp747.com
AerosoftComm= 0
AerosoftFPV= 14
AerosoftDHRST= 0
                              / Defines the action (offset 0x4F4)
                              / of the Aerosoft FPV button or DH
                              / Reset button, e.g. 14=FPV, 6=CTR
/EicasButton1=???
                              / You can define the action (offset
                              / 0x4F4) of each of the 10 EICAS
                              / buttons by setting the corresponding
                              / value here (e.g. EicasButton1=71,
                              / EicasButton10=87)
[EPIC]
DisableRemoteMCP=Off
                              / Set to on to disable input from
                              / other programs using these offsets
                              / via FSUIPC
                              / Syntax: input type = joystick,
                              / axis
[Extra]
NoFSCOptions=Off
Okay now that we know this, my actual plan was to use the white button on wxr radar to send a key press of CTRL+SHIFT+A to clear UT2 traffic. Is this possible at all
Secondly I have never been able to fully trust the PM AutoPilot so I use the default for  now, what are the best values to get realisitc AP operation where it doesn't hunt the localizer or oscollate up and down on the GS?
Right now for best results I am using the FS Autopilot as well. The PM Autopilot just hunts way too much.
Hey Angelo,
Hang in there, I will get some more answers for you soon... Tell me what you figured out about the cargo button and the WXR white button, if anything thus far.
