October 17, 2026, 01:26:36 AM
373 Guests, 1 User
  • Online today: 877
Guests: 373
Total: 374
Polulu Cards
Started by Miguellima, July 27, 2017, 01:34:18 AM
Miguellima
Dear friends
I need help setting up my two 12v Polulu's cards, I have been trying to enter the right values in each tab, but I have no clue what is the right values to enter, I have spent hours reading and trying to no avail.
I have played with JrK Configuration Utility software,  the levers move forwards and backwards when I run the motor.
In Prosim, I went to Config/ Levers  I selected both throttles ,one throttle to each  Polulu card,Analog input ,servo output, Feedback input, and motor output as you said in one of your posts.
When I load Prosim Server , the motors lockup, after that, I can't calibrate the levers in Prosim
I want to control the two motors from my QT , it's a RSP plug and play version, most of the QT works fine with the software provided , except the thrust levers when you press the A/T switch.
I have attached two pdf files that shows the current setting of the two cards
thank you
Miguel
