Solenoid Engines Start Switch Installation
Started by zeineddine, August 13, 2017, 09:49:57 PM
zeineddine
Hello everyone. I had bought the Simworld solenoid engines start switches and I have the Opencockpits Overhead. I am just not sure about some specifics for the installation and would truly appreciate any help. The connections to the inputs should be straight forward since I can use the same connection on the existing reglular switch. Connecting to a 12V DC is basic of course. I read somewhere that a Diode is needed to protect the computer from the electromagnetic field generated by the coil. I have no clue where to get that and how to do it. Also, it needs relay output coming back to it. How do I conenct a relay output from Opencockpits and would the Open cockpits Relays card work? (I have one).
Please help. Diode??? Relay output???
Many thanks
Do a google search for a 1n4142 Diode.
Order one and make sure the "WHITE LINE" on the diode connects to the same post on the solenoid as the +12V one and the other Side of the Diode goes to the Negative Post of the Solenoid.
(Essentially wired in parallel with the Solenoid" Keep in mind if you put the diode backwards.... (You will blow your power supply fuse)
Yes you will run 12V through your Relays card, and pass it onto the +12V pin of the solenoid.  Your Negative wire will go straight back to your Neg of your power supply.
The relay will act as a electronic switch, so when you write a program to make the switch "Close the relay" (During Start) and once your Starter kicks out "Open the relay" to disengage the solenoid.
Please don;t ask me to help you with the program, because I have no idea about open cockpits... Just helping you out with the Diode and answering your question about the relays card.
zeineddine
Thank you so much Trev. Truly appreciate your help.
